Swapping a K20Z3 or a K20Z1 head on a K20C2
  1. madmax1698
    madmax1698 Member
    Sep 6, 2019
    Montreal
    2016 Civic EX Sedan
    So I've been thinking lately about how nice the 8th gen Si and the RSX type-S sounded when accelerating and crossing over into Vtec.
    Knowing that the 8th gen Si/RSX type-S and the 10th gen base engine a somewhat the same bottom-end, would it be possible to swap a head from the old Si/RSX type-S onto the 10th gen's K20? The only thing that might prevent the swap being reliable is the different compression ratios (11:1 for the Si/RSX type-S vs 8:1 for the new Civic).
    I know that the K20Z3 head and K24 block has been done a few times and well documented on the forums, but what about this swap?
    If it's possible to do it, any ideas on the power figures?
    I'm pretty sure no one is going to actually do it because there is a 10th gen Si and CTR available, but what if money wasn't an issue, is it doable?
  2. xcoreflyup
    xcoreflyup Senior Member
    Nov 15, 2016
    667
    305
    Orange County
    2017 Hatchback Sport
    Totally doable it. It is the time commitment that will challenge you. If you work a full time job, this will easily be a 6 months to a year long project. You might as well do a manual swap if you have a CVT.
  3. swah_fk7
    swah_fk7 Walking JDM Parts Catalog
    Mar 31, 2018
    504
    252
    Miami, FL
    Martin
    2019 Honda Civic Si Coupe
    Completely different engine. Nothing will line up on the head as they are completely different engines. The only thing they share in common is the K in the name.
  4. mvela
    mvela Senior Member
    Sep 13, 2018
    622
    271
    Orange, Tx
    Actually the new k20c2 has a 10.8:1 compression ratio
  5. mvela
    mvela Senior Member
    Sep 13, 2018
    622
    271
    Orange, Tx
    What I would like to know is how hard it would be to build a K20c3 from a K20c2. They sound more similar than a c1 or c4. The c2 and c3 have the same compression ratio along with the same Vtec engagement. The c3 sounds like a turbocharged version of the c2.
