Suspension sounds on the 2018 Type R
FK877
Johnny
Sydney, Australia
Honda Civic Type R 2017
I had a local Type R friend here in who mentioned he had the same problem from Day 1 of ownership. I also compared it to my own R and his definitely had a knock over speed humps, driveways etc. It was more noticeable reversing into a drive way. After 3 months Honda had worked out it was his "Steering Rack Inner Tie Rod End".
He said that "they took swapped the rack from their demo car into ours and vice versa, the knock was louder in their car after the swap they said the tie rod was binding up when it got hot and was adjusted wrong from the factory".
You may want to have yours checked out.
mmcglasson
Mason
Baltimore, Maryland
2014 Subaru BRZ
Interesting.
Type R 761
Marco
Montréal, Canada
FK8 Civic type R and VW sportswagen AWD
Does anyone get a front end clunk when going over speed bumps?
I had a clunking when hitting bumps, turned out to be shock tower bolt had gotten loose on driver side. Dealer put lock tight and re torcked. Problem solved
Brandondan1
Brandon
Dallas, TX
2018 CTR, 91 Civic Si
Thanks! I have done the camber mod where you remove the extra pin from the shock tower, but I’ve double checked the torque on the other 3 tower bolts since then. I guess it can’t hurt to check again!
I hate to take the car to the dealer for anything because of certain horror stories lol.
rohnin
Iris
Honda Civic Type R
I hit a pothole and some hard bumps and now I get an occasional creaking from the front suspension when starting off and turning. Has anyone else experienced this, is something damaged?
bnotes17
noel
springfield, vt
2017 honda civic type r ; 2018 subaru wrx sti
mine is a 2017 type r that's almost a year old this sept. but, only has 2850 miles to date. it started just yesterday, like a spongy, springy type noise coming from the suspension., passenger side. I just installed an invidia r400 yesterday and thought initially, I messed something up. but, I really thought it was coming from the suspension, 1-5 mph, while making a turn on my driveway. it had happened twice so far and am still investigating and your description seemed similar to mine. i'll keep you posted as I don't use my type r so often.
Lust
Michael
Bay Area
2019 Champ White Type R
Mine creaks as well and I did hit a pretty big pothole. I’m also lowered on swift springs
sean465
London
Championship White Civic Type R FK8 R-03927
Fish
Australia
FK8 CW
Just started to have suspension sound from the front right side.
It's repeatable by reversing while turning left.
It sounds like metallic spring noise with some squeal.
visibly cannot see anything wrong
mazotyper
Ron
NoVa
2018 Honda Civic Type R #12386
Exactly same issue with my stock 18'R with just 2800 miles... such disappointment. :mad:
slowride
Midwest
2018 PMM Type-R
Holy shit, me too! Just came looking for something like this because my front right made a really weird metallic grinding/popping noise that scared the hell out me...I thought I ran over something pulling out of my driveway.
@Fish
ez12a
CA
18 CW Type R
grinding noises are a little different than knocks and can be caused by stuck rocks. Happened to me already once.
I too am getting a slight knock noise when starting from a stop. At one point i thought I heard it knocking while at speed as well... maybe i'll get it checked out when i take it in for an oil change. Just worried that they'll hammer the thing to "replicate" it.
Lust
Michael
Bay Area
Mine is becoming more frequent, usually starting from a stop. Anyone have this looked at yet?
idragmazda
CT
Fk8
2018 here - got a "clunk" sound twice when reversing slowly with the wheel turned. It almost sounded as if I gently hit something with the car. Was weird.
