Sunroof Wind Deflector Noise (when open)
  1. piterek
    piterek Member
    Jul 1, 2019
    Ontario, Canada
    Peter
    2019 Civic Hatch Sport Touring, 2015 Yamaha FJ-09
    Experiencing harsh wind noise from the sunroof wind deflector on my 2019 hatchback at city speeds. I came from 8th gen car, where the wind noise was pretty much non-existent in comparison. That was my first car with a sunroof, and I absolutely loved it. This 10th gen car is something else... I also ride a motorcycle, and the noise in the hatch is reminiscent of the wind noise in my helmet when I forget to wear earplugs. The side window also generates lots of noise when open part way. Looks like Honda Engineers forgot to go through the entire checklist during wind-tunnel testing.
    Noticed that the noise subsides almost entirely when I collapse the wind deflector down with my hand... but that's obviously not a solution. Is there a fix to this, other than shelling out money for the moonroof visor... and will that even fix the problem?
    Insight appreciated. Cheers.
    Papayank thanked this.
  2. Mikeybc
    Mikeybc Senior Member
    Apr 15, 2017
    308
    128
    Northern Ontario
    2017 Civic Coupe EX-T, 2015 Nissan Murano
    Hmm my coupe doesn't have the deflector but it has the channels and hardware bits for a defector. You can remove the deflector and it will be quieter but then you'll get that annoying low frequency buffeting noise that's hard on the ears at about 30 mph or so, I actually wish I had the defector...I'll take yours :)
    piterek thanked this.
  3. OP
    piterek
    piterek Member
    Jul 1, 2019
    Ontario, Canada
    Peter
    Will try tweaking or removing it... thought they all came with the deflector. The sound is annoyingly high pitch, and unless at very low speed, it is impossible to tune out. I end up running the sunroof in tilt mode.
    Thanks for the tip.
  4. marauderguy
    marauderguy Senior Member
    May 20, 2017
    256
    180
    Alberta
    2017 Civic Touring
    I bought the Weathertech sunroof visor and really do love it. I can have it wide open at highway speed and it is not loud at all. The only reason I bought it is because I had my closed sunroof shatter from a rock while on the highway. Looks are subjective but I think it adds to the looks and makes it a little more unique.
  5. OP
    piterek
    piterek Member
    Jul 1, 2019
    Ontario, Canada
    Peter
    I might have to consider one of these, WeatherTech or Honda, and don't mind the look... just weary of the thing becoming a water bucket. I noticed the Honda option has weeping holes in it. Do you remove for the winter?
  6. marauderguy
    May 20, 2017
    256
    180
    Alberta
    2017 Civic Touring
    I haven't used it in winter yet. I'm not planning on removing it but I don't really expect any problems with it.
  7. JT Si
    JT Si Senior Member
    Mar 17, 2019
    415
    312
    Willamette Valley
    JT
    2018 MSM Civic Si
    Do we really have the mounting points for the deflector? It's only $30 at HondaPartsNow.
    I really wonder what Honda's thinking with some models having the deflector and others not. It can't be they actually made an informed decision with regards to body style aerodynamics given we have the expected problem at higher speeds without it and OP's got the expected problem at lower speeds with it...
    If it's easy to remove, you might as well take it off and see how it does IMO.
  8. Mikeybc
    Apr 15, 2017
    308
    128
    Northern Ontario
    Yes, I parked my coupe beside my sons 19 hatch and all the spots that the deflector mounts to and the slides are there. Everything looks the same.
    Only noise issue I have on the coupe is at around 25 mph. At all Highway speeds there is no ear pressurizing buffeting noises.
