They are little rocks stuck between the rotor and the splash shield. Sticky tires kick them up all the time. They should fall out in a few yards.Does anyone get random noises coming from their car? i've recently had a sharp mechanical scraping noise coming from the front end of my car after a few pulls, the noise was only their for a bit but its gone, anyone else have had this problem?
Would the resulting sound be alsmot as if something metal was scraping on the floor as you drive? I pulled over immediately and looked as I was convinced something came loose or had run over soemthing metal and it was under the car. But it was perfect underneath after a thorough look ...They are little rocks stuck between the rotor and the splash shield. Sticky tires kick them up all the time. They should fall out in a few yards.
It is definitely the usual culprit of weird noises on the R.Would the resulting sound be alsmot as if something metal was scraping on the floor as you drive? I pulled over immediately and looked as I was convinced something came loose or had run over soemthing metal and it was under the car. But it was perfect underneath after a thorough look ...
Cheers
I am having the same issue when I’m doing a pull. It’s like a high pitched scraping sound. It sounds like air being sucked in in the video, but in person it sounds like metal scraping really fast. You can hear it at 0:03 and 0:08. Can’t find out what the issue is.Does anyone get random noises coming from their car? i've recently had a sharp mechanical scraping noise coming from the front end of my car after a few pulls, the noise was only their for a bit but its gone, anyone else have had this problem?
