Stock Type R basic Track Prep?
  1. RacingManiac
    RacingManiac Senior Member
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    2016 VW GTI, 2018 ABM CTR R-17001
    So I am thinking about doing the TNiA event later this year. Whats the minimum I need for the car to do it? Stock pads/fluid will hold up? Do I need to get the tow hook situation sorted? Factory fill 0W20 will survive?
    I'll probably do my first oil change after that. And I am planning to just run on the factory Contis since I won't use them for anything else.
    Any ideas are appreciated....
  2. totopo
    totopo Senior Member
    Apr 3, 2016
    347
    287
    CA
    '17 Civic Ex Hatch, 370z
    minimum necessary? probably nothing. just need some blue painter's tape and a favorite 2 digit number (preferrably without 2,5, 6, 8, or 9)
    Be sure to watch your engine temps. Even if you don't technically overheat and go into limp mode, I think like basically all modern OEM cars are a little sketch on the oil temps. I think most motor oil starts breaking down around 260F, which is well below limp. On a 20 min session I think it's prudent to take one cooldown lap in the middle (or like 80% of a cooldown lap so you can get the run up to the last turn and not spoil the next lap time). Note cooldown lap does not mean slow as F and boring. It means no slogging the engine, you can take turns plenty fast still.
  3. OP
    RacingManiac
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    yeah I think I'd do my normal thing for track day, I just drive between 70% and 90% in the 20 mins....
    Any other way to monitor temp other than dummy gauges?
  4. totopo
    Apr 3, 2016
    347
    287
    CA
    Oh I thought you were asking as a first timer. Dunno if stock form takes up to serious driving.
  5. OP
    RacingManiac
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    I won't be doing any serious driving, I've done like 4 track days in the last 4 years lol. I've mostly stuck to autocrosses. The plan is just to have fun with the stock car before the season is out in the midwest and try take advantage of the fact that the car is probably better at that than the GTI is. My MO at track day mostly is just to work up to my limit and try not to get too worked up in a session.
  6. racer
    racer Senior Member
    Jul 31, 2018
    498
    270
    Virginia
    Dave
    2018 Civic Si sedan. I drive a manual not because it is easy.. but because it is fun
    Going to Gingerman? Depending on experience level (and yours sounds pretty low) stock should be ok. Watch your temp guages, your mirrors and keep the ego in check. One great motivator of keeping it safe is the reminder of having to drive home in the same car you track. Seen many folks do silly things over the years.. mostly run out of talent or luck ;)
    Have fun!
  7. OP
    RacingManiac
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    Yep Gingerman, it'll be my first planned any kind of performance driving outing with the new car so its mainly meant to serve as some kind of acclimatization thing. This is like my first time to Gingerman in 6 years so plenty to be rusty about too.
    the fear of financial ruin and personal harm is a great motivator not to be an idiot with a DD....:D
  8. totopo
    Apr 3, 2016
    347
    287
    CA
    Yeah, my fear is too great, I usually go with track insurance even though it is pricey.
  9. OP
    RacingManiac
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    Bought that too, with the Hagerty deal going on with TNiA I was able to get entry for $100 and insurance for $132 with a relatively high deductible. But still obviously less than buying a new car....
    TNiA obviously doesn't have as much track time as a full day thing but 3 20min session should get it started for that first hit....lol
  10. baldheadracing
    baldheadracing Senior Member
    Jan 4, 2017
    1,165
    1,260
    Canada's capital
    Craig
    FK8
    I boiled the stock brake fluid and ate up the rear pads in two sessions @ Gingerman in the spring. That track is hard on brakes. Went with RBF600 and Hawk race pads for Gridlife (same setup as Johnny had in the spring) and had no issues once the pads were bedded in.
  11. OP
    RacingManiac
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    Ok I might either get a carbotech setup for the car and just hang on to them(1521 for street, XPs for track on the same rotors) or I might end up buying Johnny's setup. I have ATE Type 200 that I can flush the system with so fluid front is ok.
    What tires did you use?
  12. baldheadracing
    Jan 4, 2017
    1,165
    1,260
    Canada's capital
    Craig
    FK8
    RE-71R's. Literally the first time I had ever run RE-71R's.
    BTW, Hawk has just discontinued the Street/Race compound (used on the rear). I'm going to try Carbotech or g-Loc (more-or-less the same compounds supposedly) next.
  13. OP
    RacingManiac
    Jul 29, 2018
    350
    175
    Detroit, Michigan
    Jen
    So Gingerman TNiA was yesterday and it was pretty fun. I ended up buying all of Johnny Rose's parts from his CTR that he is selling. So I flushed my fluid with ATE Type 200 and ran his spare front rotors used with DTC60 pads and left the rear stock. Ran 3 sessions with TNiA in Intermediate group. Car was easy to drive and never had any brake issues. Stock Continentals seems pretty ok with the abuse though not sure if the laptimes were anywhere near anyone running 200TWs. I would push 95% for maybe 3-laps and would notice the water temp gauge would move from the normal below center position to above center and I would back off for a lap or so and it'll go back down. Never felt the car pull power or anything. Using the auto revmatch is pretty cool. Felt like cheating, lol. This was the first time I hit the track in 4 years I think and 5 years since I last went to Gingerman in my older MK6 GTI. Had a pretty fun time.
    ApexEight thanked this.
