Stock Brake Pad Replacement
shipdawg
Austin
Orange County, CA
2019 Honda Civic Type R, 2004 WRX STi, & 2019 Honda HRV EX
Has anyone replaced their stock brake pads with performance pads? Been doing a ton of canyon driving lately and need better pads. I already changed the brake fluid to DOT 5.1 to get the boiling point up.
So far I have been looking at the Optimum OEp Pads by R1 Concepts and the Hawk Brake Pads. Any experience with either of these brands or suggestions on other pads that you would recommend?
Design
Southern California
09 MS3, 17 ABM Si Sedan
I've used HPS in the past on the MS3. Slightly less initial bite, but very quiet and consistent.
I will probably do them again when it's time to swap out the OEM front pads.
Yonder
Miguel
San Diego
'18 Civic Si
I've looked through the autocross threads in the past and remember seeing brake pad discussions for DD, Track use, and Autocross. I'd try my luck in that section for brake pad comparisons if you havent already done so. From what i remember Stoptech was a well regarded pad.
shipdawg
shipdawg
Austin
Orange County, CA
Thanks! I'll dig a little deeper and see if I can find something. Searching hasn't proven too fruitful. Definitely will checkout Stoptech.
Yonder
Miguel
San Diego
'18 Civic Si
Yeah i started looking after your post and didnt find a whole lot lolol Down side to having a newer aftermarket car... Not as much R&D :/ I know 27WON is competing in SCCA Time Trials this year so im sure they will have a "break" down (sorry for the Dad joke lol) of their setup.
shipdawg
shipdawg
Austin
Orange County, CA
Hopefully they have their brakes down so they don’t break down
SlowAP2
Terry
FL
19 SI, 04 S2K,
Carbotec, Cobalt, and I believe gloc will make pads for anything if you send them a backing plate size. I'd avoid anything Hawk if you like your wheels, very corrosive. Any more aggressive pad will dust alot but some like cobalt and Hawk are corrosive dust that will eat your wheels. I'd like to try the Ferodo DS2500 for autox but don't think its made for our caliper.
Design
Southern California
I disagree, almost no pad is corrosive to the point that a bi-weekly wash with occasional polish/wax can't mitigate. What most people DO notice, however, is higher temp brake compound that can burn through the wheel finish over time (giving the appearance of corrosion).
A typical street pad should be fine, IMHO. I ran HPS on the MS3 with no ill results for almost 170K.
TaoBrew
Tim
Indiana
2017 Honda Civic Si
Installed Hawk High Performance Street HPS 5.0 and StopTech slotted rotors a couple of weeks ago. Am really impressed with the performance, especially when you get a little heat in the pads.
Thomas66
Thomas
Virginia
80 Rx-7, 2018 Civic Si
Are you using those pads for street use or for track use or both?
kshawn
Matthew
Maine
2017 Civic SI
Front and rear?
skorj
Kansas
2018 Civic SI sedan
I haven't used them on the Civic but I ran Stoptech on two other cars with great results. I'll be putting them on my wife's Mazda this month and ordering them for the SI sometime in the near future too.
Thomas66
Thomas
Virginia
I just replaced the front rotors but put the Hawk pads all around.
I just ordered the same set up. I plan to change out the rotors and pads before I track it then change back to stock once I get home and have time.
