Sticky Climate Control Button
  1. jeffchp
    jeffchp Member
    Sep 16, 2019
    J
    2016 EX-T
    Hey Civic gang,
    My defroster button is stuck in a pushed state. It still turns on when I press it but it also triggers whenever I hit a bump or touch anything around it (video below). Has anyone else had this problem and if so, how did you fix it?
    Thanks
  2. Ricardowelch
    Ricardowelch Member
    Sep 18, 2019
    1511 Willow Greene Drive
    Ricardo
    2016 Honda Civic
    It is possible something wrong with the button. Another cause may be loose cable. I think you should check it.
  3. shoegazer
    shoegazer assistant to the assistant manager
    Sep 5, 2018
    455
    210
    Raleigh NC
    2018 Civic LX Coupe 2.0 (CVT)
    I think a soda or coffee was spilled and is causing a sticky situation. Double check my suggestions; but De-Oxit or TV tuner cleaner (in a spray bottle with a straw), or maybe denatured alcohol would solve this issue.
  4. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    1,859
    402
    Vaudreuil,Quebec ,Canada
    +1
    Use only contact Cleaner with lubricant safe for plastic, Some low budget contact cleaner may melt the plastic.
  5. OP
    jeffchp
    jeffchp Member
    Sep 16, 2019
    J
    2016 EX-T
    I'll try De-Oxit, thanks for the suggestion. Do you think the button can be pried off and cleaned?
  6. OP
    jeffchp
    jeffchp Member
    Sep 16, 2019
    J
    2016 EX-T
    I sprayed some contact cleaner on it prior to the post. For some reason it actually made it stick more.
  7. shoegazer
    Sep 5, 2018
    455
    210
    Raleigh NC
    I personally wouldn't try to pry it off.
    But I'd take the plastic-safe cleaner and kinda direct it into the area near the top of the button (I'm guessing that's how the stuff got in). It may take several cycles of spraying and then repeatedly pushing the button to 'work' the solvent around the contacts. Or course... you should not do this with the system on. And you should let it dry completely before powering it up (at least a few minutes).
    There was another thread where someone was experiencing the trunk opening by itself. It turned out that the previous owner had spilled something on the area near the release button. This is my hunch.
  8. OP
    jeffchp
    jeffchp Member
    Sep 16, 2019
    J
    2016 EX-T
    Update for anyone else who has this problem:
    Ordered a new climate control console, was a simple swap. Couldn't fix the sticky button with any of the suggested methods.
    shoegazer thanked this.
  9. latole
    Apr 13, 2017
    1,859
    402
    Thank's for report.
    You don't know why button was sticky ?
  10. latole
    Apr 13, 2017
    1,859
    402
    Did you use Deoxit ?
  11. Swank
    Swank Senior Member
    Apr 30, 2018
    259
    142
    Calgary
    2018 Civic Si Coupe Black
    Looks like there is some crud on the bottom of the recirc button, food/drink maybe? Anytime I need to unstick buttons like that I use hand sanitizer in the crevices and give the button like 50 presses, have to do a few treatments in a day or 2 and then less and less in the future. No damage to anything, in fact the button looks brand new after.
  12. OP
    jeffchp
    jeffchp Member
    Sep 16, 2019
    J
    2016 EX-T
    Bought the car used so my best guess would be the previous owner spilled something on it. Deoxit didnt help much.
  13. latole
    Apr 13, 2017
    1,859
    402
    You never say that before.... a used car .
    And you never answer to message no 3 wich write a bout spill coffee or soda
    Anyway issue is fixed now. :thumbsup:
    Did you keep old parts ? Try to fix it.
