steering wheel not centered
  1. Dragnet
    Dragnet Senior Member
    Oct 17, 2017
    717
    212
    Huntsville, Alabama
    Joe
    2017 Civic Type R, 2016 Accord Sport
    Is it a big issue getting the steering wheel realigned? It was out of alignment from day one but I figured it might be that the tires/wheels were out of alignment. It didn't change after a rotating and balancing of the tires. I figured next time I go get an oil change/balancing done at the dealership I'd question them about it. Surely the warranty for cover such work.
  2. dc2turbo
    dc2turbo Senior Member
    Jan 27, 2016
    2,921
    2,033
    usa
    civic,teg
    you need an alignment not rotating the tires
    360glitch and Dragnet thanked this.
  3. OP
    Dragnet
    Oct 17, 2017
    717
    212
    Huntsville, Alabama
    Joe
    Do you think it's in actual need of an alignment? It feels good and doesn't pull to the side or anything. In order to keep the car straight I have to keep the steering wheel turned to the left about 15° or so. I've heard of some other folks that have had similar issues but never knew what they did to fix them.
  4. dc2turbo
    Jan 27, 2016
    2,921
    2,033
    usa
    civic,teg
    so it's pulling to the right then
  5. the8rotor
    the8rotor Senior Member
    Nov 9, 2017
    125
    82
    Fort Worth, TX
    Kevin
    '17 Type R '17 CRV '06 GTO '15 Silverado 1500
    Go get an alignment and you'll be good!
  6. OP
    Dragnet
    Oct 17, 2017
    717
    212
    Huntsville, Alabama
    Joe
    No. It doesn't pull to the right or left. If I straighten the wheel completely straight it goes to the right. I have to keep it turned left at about 15° to keep it straight. It doesn't pull though. It's like the steering wheel was not aligned when installed.
  7. dc2turbo
    Jan 27, 2016
    2,921
    2,033
    usa
    civic,teg
    you just said it... it pulls to the right if the wheel is center
  8. SonicTyphoon
    SonicTyphoon Member
    Jan 23, 2017
    47
    VA
    Civic Hatchback EX-L
    Don’t have a Type R here but I have the same exact issue on my ‘17 hatchback. Have to keep it turned a bit to keep it straight.
    It used to drive me nuts with my OCD :rolleyes: but I’ve tried not to look or think about it when driving. I’ve learned to live with it for now. May finally take it in when warranty is close to being up.
    I wonder if it could be a QA issue at the Swindon plant.
  9. OP
    Dragnet
    Oct 17, 2017
    717
    212
    Huntsville, Alabama
    Joe
    I should have worded it differently. It's not pulling as if the right front tire is low. It just feels like the steering wheel is not centered.
  10. ez12a
    ez12a Senior Member
    Jan 30, 2018
    681
    304
    CA
    18 CW Type R
    Electric steering can be wonky. Take it to the dealer.
    A few people in the lexus Gs350 forum i was a member of had the same issue with the steering not being aligned after doing some work on the car.
    related Recall:
    https://repairpal.com/recall/12V221000
  11. s2kdriver80
    s2kdriver80 Senior Member
    Nov 22, 2015
    372
    245
    Long Island, New York, United States
    MY03 Honda S2000
    Wow 15 degrees? You could argue it's a safety hazard. A couple of degrees would bother me lol.
  12. OP
    Dragnet
    Oct 17, 2017
    717
    212
    Huntsville, Alabama
    Joe
    Well probably not technically. Maybe if the wheel is perfectly centered it's actually at 90°? What I'm saying though is in order to keep the car driving straight I have to keep the wheel turned ~15° left of center... so not too much. If you're looking at the wheel as if it's a protractor then it's probably around 75 or 80° to keep the car driving straight. It's more of a OCD thing than a safety hazard. I notice it though. I'm constantly thinking about it. Is this something you think a warranty would cover if it's actually a misaligned steering wheel and not the car being out of alignment?
  13. s2kdriver80
    Nov 22, 2015
    372
    245
    MY03 Honda S2000
    Yea I know, you meant 15 degrees off. That's still quite noticeable. I'd claim it's a safety hazard having to hold the wheel like that to go straight. It would help if they already knew about this problem.
  14. Maverick1
    Maverick1 Senior Member
    Jun 4, 2018
    169
    124
    Socal
    Doug
    VW GTI
    Your car is under warranty so just take it in to the dealer and they will take care of you.
    No biggie.
  15. willimo
    willimo 14708
    Mar 16, 2018
    218
    173
    Austin, TX
    Will
    1996 Civic, 2018 Civic Type R
    Yeah just take it in. Bad alignments don't always result in a pull, an off center steering wheel can be part of a bad alignment. The toe and stuff might all be right, but they may have set it with one tie rod a little "longer" than the other side, leaving the rack slightly off to one direction. This can make the steering wheel a little off center even if the car drives perfectly. They'll fix it. They expect us Type R types to be a little finicky.
