Started the car to at least 6 problems and the engine light
CraigJ
Craig
Nova Scotia, Canada
2017 Honda Civic Si Sedan - Black FC1
I've got a 2017 Civic Si sedan. Havent had an issue with it yet. it's got 36000 kms on it.
Started it up this morning and the check engine light came on then it gave the following warnings.
Emissions System Problem
Brake System Problem
Brake Hold System problem
Power Stearing System (EPS)Problem
Vehicle Stability Assist System (VSA) Problem
Hill Start Assist Problem.
The only thing I've had done to the car since I bought it was the vehicle recall work on the ECU.
I'm not sure if I should drive it.
Anyone else see anything like this before? Seriously WTF?
Thanks
Craig
shipdawg
Austin
Orange County, CA
2019 Honda Civic Type R, 2004 WRX STi, & 2019 Honda HRV EX
I had this happen to me. But it’s been after driving really hard and I just had to let the engine cool down. Do you have an OBD reader? What’s the code?
BSbrenden97Si
Brenden
Mukwonago, WI
2018 Honda Civic Si Coupe
Thanks
Craig
I had this happen to me after lowering on D2 springs. After taking the wheels off and checking multiple times, I noticed the speed sensor was cracked and causing all this. Ordered replacement with dealership since I was in a rush but found cheaper options online. All codes cleared after.
CraigJ
CraigJ
Craig
Nova Scotia, Canada
See that's the weird part. I would expect something like this if I was driving it hard but I had just came out this morning to get in it after it had been sitting all night. It couldnt get anymore cooled down than it was.
I dont have an OBD reader but I think I'm going to have to go get one.
shipdawg
Austin
Orange County, CA
Can’t go wrong with an OBD reader. I got a Bluetooth one off of amazon for like $16. Paired with the car scanner app it’s great! It tells me what the codes mean.
mvela
Orange, Tx
You didn’t disconnect the battery for any reason did you? I know when the battery is reset for doing any type of work to the car it will cause a bunch of faults on the initial startup. You have to drive it around to make them go away
In the states most auto parts stores will scan your codes for free. You may want to check for something like that before buying one.
Civic17siYAY
2017 civic si
As others have said, get a code reader and find out what codes they were throwing.
RobXsi
Nope
Noneya
Nata
I agree with the other dude.
Replace your battery. 2+yr old battery. Heard this happen many many times due too battery.
frontlinegeek
Jason
New Brunswick, Canada
2020 CRV Touring, 2017 Civic EX Sedan Honda Sensing
Bad or almost bad batteries can cause all manner of issues. I thought the starter was going in our CRV. I replaced the battery and boom issue solved.
I definitely second checking out the battery. Check the resting voltage after it sits all night.
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
Dude, I got the exact same problem a week ago. I just opened the fuel tank cap and used emergency fuel fill funnel to fiddle with the auto shutoff valve and the problem disappeared
jason510
Jason
2019 Civic Si Sedan
For what it's worth, I had this happen to my '14 Accord. I happened to be at a light that had a Honda dealership there so I drove it in. It was a bad battery...went out less than 2 years after purchasing so it was covered under warranty. It took them like 5 minutes to diagnose in the service drive.
Please let us know what you find out.
CraigJ
CraigJ
Craig
Nova Scotia, Canada
Hey all, thanks for all the replies on this. I wanted to let you know I took it to the dealership this morning and they came back with the following:
Cause: road tested confirm all lights on and can feel misfire at idle. scan found codes P0302 misfire #2 cylinder, u0401-68 ecm failure, u0416-88 vsa system malfunction.
So it turned out that the misfire in cylinder #2 was the cause of all the warning lights. They claim to have replaced all the fuel injectors, and cross over fuel pipe and they also did a valve adjustment. So far so good no more lights.
The other issue I had were the brakes shuttering at high speeds. they found that the rotors were out of round and had excessive run out. They resurfaced the rotors to correct.
Thanks again for all the input. I'm loving this site!
Thanks
Craig
saiko21
Sai
Sacramento
Thanks
Craig
Rotors warped? How many miles you have on the car and do you drive & brake aggressively
