squeaking sound while braking
  1. et4891
    et4891 Member
    Apr 3, 2019
    Vancouver
    ET
    Civic Type R 2019
    I am curious, is the brake suppose to make a metal squeaking sound when braking? It's like 70-80 percent of the time when I brake it'll have squeaking sound BUT if I do a hard brake sometimes it's most likely 100 percent no such sound. Is this normal for the car (Type R 2019)?
  2. FifStreet
    FifStreet Senior Member
    Aug 8, 2018
    211
    112
    Oswego NY
    Michael
    '18 PMM Civic Type R '07 MR Fit Sport (RIP)
    Yes. The squeal from the brakes is common, especially at low speeds and light loads. The brake pad compound that is used is optimized for performance. The downside is noise and excessive brake dust.
    There are plenty of threads and posts around here discussing different pad options.
    et4891 and 02SilverSiHB thanked this.
  3. Chi_The_Process
    Chi_The_Process Senior Member
    Feb 24, 2019
    59
    39
    Minneapolis
    2019 Honda Civic Type R
    The factory brembo pads will squeak regardless. Get some hawk HP pads and your problem will go away.
    et4891 thanked this.
  4. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    1,249
    628
    Illinois
    Marcus
    '18 Civic Type R (RR)
    This is normal. You can mitigate a lot of the noice by braking hard as you have already noticed. With your windows closed you can apply a minimum of 150-200 PSI of brake pressure and you should never hear the brakes about 95% of the time unless you’re doing a ton of soft braking.
