squeaking sound when turning left
  1. AJ28
    AJ28 Senior Member
    Oct 29, 2017
    61
    60
    Anthony
    Honda Civic SI 2017
    I get this strong squeaking noise every time I turn the steering wheel left or about 20 degrees at freeway speeds. I've checked brakes if anything was rubbing with rotor and also the ball joint boot. I was wondering what else could be the cause? TIA
  2. iShift_6
    iShift_6 Member
    Mar 10, 2018
    60
    New Jersey
    Doug
    2017 Honda Civic Si Coupe WOP
    I was/am getting a squealing sound when the wheel is just left of center or turning left, which goes away when the brakes are applied.
    When you checked the brakes, did you check the brake pad retainer clip?
    In my case for whatever reason, it is moving around, even thought it has bends on it that should prevent that.
    For me, the upper clips slides towards the wheel, leading the back edge to rub on the rotor, and sounding like the squealer on the pad hitting the rotor.
    I have yet to take everything apart to see what is actually wrong, that should be next weekend.
    In the interim I have re-positioned the clip by gently tapping it with a hammer and a piece of brass rod at the corners.
    It only needs to move about .050 of an inch, so not much force is needed.
    Hope that helps.
  3. sesty
    sesty Senior Member
    Oct 16, 2017
    75
    Jersey Shore, NJ USA
    Civic Si Sedan
    Going in for service for this exact issue on Wednesday..
    Pulled the wheel and pads off didn’t solve anything but I didn’t pull off the clips
  4. davidpeab
    davidpeab Senior Member
    Sep 17, 2017
    56
    39
    Pasadena, MD
    2017 Honda Civic Sport Touring Hatchback
    I'd have them check the struts
  5. OP
    AJ28
    AJ28 Senior Member
    Oct 29, 2017
    61
    60
    Anthony
    Honda Civic SI 2017
    I found the problem. It was the brake pin holding the brake pads rubbing on the rotor. Just had to get a flat head screwdriver to bend it back into place and its back to normal :)
    sesty and kshawn thanked this.
  6. Matthyahuw
    Matthyahuw Senior Member
    Apr 15, 2018
    661
    346
    Valley of the Sun AZ
    Matthew
    2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
    Thanks for the follow up. Have you had a brake job yet, or has this pin worked it's way out from the factory?
    RobXsi thanked this.
  7. stickshiftnewbie
    stickshiftnewbie Senior Member
    Dec 7, 2017
    220
    35
    San francisco
    Phel
    10th gen SI
    Do you have a picture? And did you have a brake job before it happened?
  8. jason510
    jason510 Senior Member
    Feb 22, 2019
    114
    97
    Occupation:
    Teecher
    Jason
    2019 Civic Si Sedan
    x2....Good questions. If it was after a break job not done at the dealership, it wouldn't be covered under warranty right?
  9. REBELXSi
    REBELXSi Señor Member
    Aug 12, 2018
    1,462
    1,205
    S/E PA
    '18 Si Coupe
    I have this issue intermittently. Car is still on the factory brakes. I'll see if your solution works. Thanks.
