Squeaking moonroof
  1. bigdodog
    bigdodog Member
    Dec 5, 2018
    Orange County
    Civic Si 18
    Hey guys,
    Has anyone experienced moon roof squeaking issue on 10th gen Civic?
    Mine is a 18 Si with under 2k miles. Yesterday the moon roof started to squeak even when i drove on well paved roads.
    It is not the popping sounds that a lot of people reported on the 2016 Civic where the metal frame touches the plastic part. It is like a buzzing noise.
    I fixed it temporarily by tapping the moon roof couple of times after closing it. It appears the seal is rubbing against the car frame. I am pretty sure the noise will come back sooner or later. Anyone has experienced this and came up with better permanent solution?
  2. nikkon
    nikkon Senior Member
    Aug 2, 2017
    68
    Romania - Europe
    Mihai
    civic 1.5T
    Hi,
    I have the same issue. Honda dealer already changed the mechanical parts but does the same. The noise is terrible when I go over bad road. No official fix so far
  3. BarracksSi
    BarracksSi Senior Member
    Apr 1, 2017
    1,903
    1,086
    DC
    If that's all it is, wipe some silicone lube on the seal. Pop the moonroof in "vent" position, spray some lube on a rag, and wipe it onto the rubber.
    Some slight movement between the glass and the roof is normal as the chassis flexes and/or air turbulence pushes and pulls against the glass panel. If it fit too snugly, chassis flex could break the glass, so the solution is to design a bit of a margin around the panel.
    saz468 and bigdodog thanked this.
  4. raynist
    raynist Senior Member
    Jun 10, 2018
    280
    76
    Pittsburgh
    Ray
    2018 Cosmic Blue Civic EX-T Manual
    #4 raynist, Mar 1, 2019
    Lube the rubber and the metal track with honda’s White grease. Mine was really bad when I bought it. Applied this liberally and 8 months later still no squeaks.
    saz468, bigdodog and BarracksSi thanked this.
  5. OP
    bigdodog
    bigdodog Member
    Dec 5, 2018
    Orange County
    Civic Si 18
    I am going to try when it happens again. Thank you!
  6. stoobs
    stoobs Member
    Feb 7, 2019
    UK
    Stoo
    UK Honda Civic Prestige CVT 2018
    I've had my CivicX in to Honda for roof 'noises'. They seemed to have cured the sunroof rattle, but not what I believe is the moon roof rattle.
    Exactly where is best to apply the lithium grease to alleviate moon roof rattling? Is it best done from the outside of the car with the sunroof open and the moon roof closed, or what?
    I look forward to your suggestions.
    Thanks.
  7. raynist
    Jun 10, 2018
    280
    76
    Pittsburgh
    Ray
    I did it every way I could - from in the car with the moonroof partially open, fully open and from outside. I mostly applied it to the track using a q-tip and liberally applied it.
  8. stoobs
    stoobs Member
    Feb 7, 2019
    UK
    Stoo
    Thanks for the response.
    Is this the rail where the plastic moon roof actually runs? It appears to have a nylon chord running through it (on both sides) too.
    I am unable to easily get hold of Honda's White Grease (which is lithium based) in the UK. Would a spray-can lithium based grease be sufficient or does it need to be quite thick?
  9. JohnnyL
    JohnnyL Senior Member
    Jan 19, 2019
    03766
    2019 Civic Coupe EX
    Go to a parts store and get some silicone spray lube and put it on the rubber area around it. Might work. Use it on any of the rubber seals on the car. Doors, windows, trunk and hood lid.
  10. raynist
    Jun 10, 2018
    280
    76
    Pittsburgh
    Ray
    I put it on really thick just to make sure. I would think any lithium grease would work. That the spray grease and spray it on a piece of cardboard and then use a q-tip to put it on thick along that track. I will post a picture of mine later.
    stoobs thanked this.
  11. shoegazer
    shoegazer assistant to the assistant manager
    Sep 5, 2018
    140
    68
    Raleigh NC
    2019 Civic Sport Coupe 2.0 (CVT)
  12. raynist
    Jun 10, 2018
    280
    76
    Pittsburgh
    Ray
  13. shoegazer
    Sep 5, 2018
    140
    68
    Raleigh NC
    #13 shoegazer, Apr 23, 2019 at 8:06 PM
    If you Google "shin-etsu" or the part number; there should be many options.
    Edit: But it looks like Honda has stopped selling this in Europe?
    So definitely not easy or convenient. But the eBay sellers are willing to ship.
    Good luck with it. Even if it doesn't solve the problem; you'll make all the rubber seals last forever.
  14. stoobs
    stoobs Member
    Feb 7, 2019
    UK
    Stoo
    Thanks all. I'm still not completely clear where this should be going.
    There is no 'rubber' in the plastic moon roof runners.
  15. stoobs
    stoobs Member
    Feb 7, 2019
    UK
    Stoo
    Where abouts should it be applied?
    Where the rail of the moonroof is as per the yellow highlighted area?
