Sport Mode with electronic waste gate actuator disabled
Tags:
  1. Coolnezzz
    Coolnezzz Member
    Jun 25, 2018
    43
    2018 Civic Si Coupe
    #1 Coolnezzz, Feb 24, 2019
    Hi KTuner,
    As there will be more aftermarket turbo kits in the wild as time goes on I was wondering if there will be a possibility of getting the sport mode button on the Si enabled again while the electronic wastegate actuator is disabled in the tune. Currently with the stock ECU and KTuner, with PRL's turbo kit we are unable to use sport mode and I really miss the steering and damper firmness settings.
    Also curious about running the stock electronic WGA on after-market turbos and if there is coding to support that yet, assuming we could overcome the physical limitations of the intake piping and re-install the stock electronic WGA that is.
    Thanks!
    edit: literally minutes after posting this it looks like progress is in fact being made on adapting the stock WGA to the PRL kit, so that would solve both of these questions. Looking forward to results!
    KramVT0215, dallasjhawk and KTuner thanked this.
  2. KTuner
    KTuner Senior Member
    Jul 10, 2017
    2,014
    2,581
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    Was going to mention the testing that's taking place, but looks like you saw it already!
    KramVT0215, dallasjhawk and Coolnezzz thanked this.
  3. PNW_FC3
    PNW_FC3 Senior Member
    Oct 19, 2017
    139
    84
    Washington State
    Rae
    2017 Civic Si Coupe
    where can i find this info?
  4. 360glitch
    360glitch Moderator
    3,880
    3,738
    2017 Civic Si Sedan
    Back to the original question, can we look forward to the return of sport mode with the EWG disabled at some point later down the road?
  5. OP
    Coolnezzz
    Coolnezzz Member
    Jun 25, 2018
    43
    2018 Civic Si Coupe
    Yeah I'm also still curious, it might be a while before the masses can start bolting the stock electronic WGA to the kit.
