Sport Hatchback Battery Size?
cestjoel
2017 Civic Hatchback Sport CVT
Does anyone know the size of the Sport Hatchback battery? I'm trying to find an Optima Gold top. But, according to their website, they don't have one that fits. I'm getting slight headlight dimming and would like to replace the battery.
Thanks in advance!
cestjoel
cestjoel
Space Lord
Midland, TX
2016 Honda Civic
EMPhoto
Eric
Fairfield, Calif.
I work for the green top guys (not naming the name) Our part number is
SC51RDA for the yellow top optima, been looking at getting one myself.
cestjoel
cestjoel
Thank you! :)
PaulD
Paul
Huntsville, AL
2018 civic Si coupe, 2001 Accord Ex coupe
Be careful of some of these battery replacements designed for bass heavy car audio. Problem 1 is that all too many of them do NOT like to be charged above 14V, problem 2 is that a battery is just another load once the car is started - unless you are drawing more than the alt can sustain.
Syseen
Milwaukee, WI
2021 Civic Hatchback Sport 6MT, 1982 Suzuki GS750T
I read on a different forum that a d35 would fit (at least in Canadian models) but I had no such luck today. could be pretty easily done but the one i picked up from autozone was $290 after the core charge and like 15 minutes after buying it i got a code for $50 off if i bought a 51r online. so returned the 35, and installed the stock size (saved like $90 compared to the 35).
Ill let you know how it goes. I went this route because i have to leave my car parked in the Ohare surface lot for weeks on end when i travel for work. the OEM battery was always flat unless i put a solar charger on it. Even then with my dash cam i only got maybe a day or two at most of recording before it shut off at 11v.
**UPDATE*** 11 April 2019
So far the factory sized yellow top battery is working great. the Dash cam seems to be running for days on end without shutting off or killing the battery. Earlier today i had the car on but not running for about a half hour while i hacked the head unit, and uploaded a base tune to the ECU.
Well worth the price.
Lazerline19
NY
2017 Civic SI
can anyone confirm these optima 51r fit without mods? direct replacement?
