Spoon Springs Install DIY
Koomoo88
Michigan
2000 Civic SI
Anyone here in the Michigan area that could help, will pay in booze,pizza, and some dough
sosoye
Brandon
Atlanta
Civic Type R, S2000, Turbo Miata
Was a spring compressor required to swap the rear springs?
FK8_JJ
Jose
Las Vegas
18 Honda Civic Type R, 92 Civic Si, 04 Honda S2000, 13 Toyota Tacoma
You won't need a spring compressor for the rear. The rear pop out easy, just loosen up the lower control arm bolt closest to the wheel and the sway bar bolt and drop the control arm and you'll be able to pop it out. Just use a jack to put everything back together.
ItsmyfriendSteve
Steve
Orlando
2019 FK8
Not to resurrect an old thread, but just wanted to share that I appreciate the original post and the suggestions from the community through out. This helped this new owner complete my install on my own.
one thing I did (judgement free zone) to help me not struggle as much with the front was that I jacked up the front control arm to compress the spring. I then used heavy duty zip ties while compressed to hold the compression. I know this could be dangerous, but thankfully it held. Ultimately helping this weak “do it yourselfer” be able to complete on his own.
Honda Civic 10th gen Spoon Springs Install DIY 37BA715F-8CAA-4AE1-B1DD-F4F92388B847
