Spoon Springs Install DIY
  1. spoonsportsusa
    spoonsportsusa Spoon.Official
    Jun 29, 2017
    124
    Orange, CA
    FK8 Civic Type R, FD2 Civic Type R, GK5 Fit RS, S2000
    #1 spoonsportsusa, Aug 17, 2018
    We've swapped the springs out a few times already so we just wanted to share the method that is quickest for us. Total time for the front is about 1 hour and rear is 10 minutes.
    Front
    1. Remove undertray (to access lower arm bolts connected to the subframe)
    2. Disconnect the swaybar end link side that attached to the strut on BOTH sides of the car by removing the nut. This prevents the suspension from binding when dropping the strut. Pull the link out of the strut.
    3. Disconnect damper electrical connector (pry the tab up in the gap).
    4. Remove the bracket holding the connector line and brake line.
    5. Disconnect ride height sensor bracket that connects to the lower arm.
    6. Disconnect the front suspension link. (behind plastic brake air guide)
    7. Remove the bolts that hold the front lower arm to the subframe. (3 bolts)
    8. Remove the two pinch bolts holding the bottom of the strut
    9. Remove the nuts on the top of the strut to the body.
    10. At this time you can pull off the locating tab in order to get some extra camber in the front.
    11. Pull the lower arm out of subframe and be careful not to pull the driveshaft out. At this time the whole assembly should be loose and provide enough clearance to wiggle the strut out. (Sorry no proper picture here)
    12. Use spring compressors to compress the spring and take the top nut off holding the hat.
    13. Cut off one section the bump stop.
    14. Transfer over the rubber bases and take note of how it slots onto the spring and bottom perch.
    15. Compress the spring and install it on the strut. Make sure all the rubber pieces are correctly positioned as they tend to shift during assembly.
    16. Reinstall onto the car in reverse order.
    Rear
    1. Remove the bolt holding the swaybar link to the lower arm.
    2. Remove the bolt holding the lower arm to the knuckle.
    3. Pull the lower arm down and the spring should fall out.
    4. Transfer over the rubber perches and take make sure the tabs are aligned when reinstalling.
    5. Put a floor jack under the lower arm and raise it until the bolt holes line up.
    6. Reinstall the two bolts.
    jcp227, iShift_6, 4DaFanS and 23 others thanked this.
  2. 98-0425
    98-0425 Senior Member
    Jun 18, 2017
    841
    624
    Las Vegas
    Nick
    18 Civic Type-R #12307, 98 Integra Type-R #0425, 07 Pilot EX-L, 17 Pilot Elite
    Great write up!
    hafadaze thanked this.
  3. anhanymous
    anhanymous Senior Member
    Jan 27, 2018
    123
    47
    Maryland
    2018 CBP CTR, 2009 Accord
    these pictures make it look like a walk in the park :respect:
  4. 00057
    00057 Senior Member
    Nov 9, 2017
    823
    831
    Occupation:
    Ferrari
    SATX
    2018 BMW M3CS / 2017 Chevy Tahoe Z71
    That’s a great write-up for tech-docs!
    Would like to see how the ride hidth settles at; pictures of the FK8 after the installation?
  5. Hondanickx
    Hondanickx Senior Member
    Jun 10, 2018
    354
    168
    Belgium
    Nick
    1998 civic hatch , 2018 White civic sedan
    Are those Front springs also the stock Type-r ones?Looks like those are progressive from the factory already .
  6. OP
    spoonsportsusa
    Jun 29, 2017
    124
    Orange, CA
    Stock vs. Eibach vs. Spoon Progressive Spring
    4DaFanS and frtorres87 thanked this.
  7. OP
    spoonsportsusa
    Jun 29, 2017
    124
    Orange, CA
    Spoon Progressive Springs
    Titan 7 T-S5 19x9.5+45
    Yokohama Advan AD08R 265/30-19
  8. Hondanickx
    Jun 10, 2018
    354
    168
    Belgium
    Nick
    Ah now i see ,you had the eibach springs on already. The stock ones are lineair like always.
  9. bouford
    bouford Senior Member
    Jun 28, 2017
    647
    434
    Pearl City HI
    Felipe
    03 AP1/18 FK8/19 CV2
  10. neveronline
    neveronline Senior Member
    Jul 12, 2018
    134
    74
    Clayton NC
    Current '19 CW CTR #23856 & '18 Accord 2.0T Previous - 2015 WRX, 1999 SI, '04 S2000, '08 Evo X, '10 SI sedan, '11 Fit Sport, '11 WRX, '13 ILX
    Thank you for the write up Spoon Sports / Go Tuning!:thumbsup:
  11. idragmazda
    idragmazda Senior Member
    Apr 21, 2018
    631
    444
    Occupation:
    M&A
    Philadelphia, PA
    Depo
    Current: 2018 Type R, 1977 CB400F; Previously: 2018 Civic Si Sedan, 2006 Civic, 1992 Mazda B2600i
    How does it ride / handle compared to the Eibachs? Thanks.
  12. 02SilverSiHB
    02SilverSiHB Senior Member
    Jan 3, 2018
    2,248
    1,373
    Annapolis, MD
    2017 FK8
    looks like spoon springs=more saggy butt
  13. OP
    spoonsportsusa
    Jun 29, 2017
    124
    Orange, CA
    #13 spoonsportsusa, Aug 20, 2018
    Eibach and Spoon are the same height down to 1/16th-inch. Swift would be lower than both Spoon and Eibach and also stiffer. So in essence the drop is the same for Eibach and Spoon
    4DaFanS, bouford, Remm and 1 other person thanked this.
  14. OP
    spoonsportsusa
    Jun 29, 2017
    124
    Orange, CA
    Spoon are more compliant than Eibach but doesn't sacrifice roll resistance. Through the corners the Spoon springs do a better job absorbing bumps and stays well planted. Eibach are a little stiffer than Spoon but you get sharper steering response but the tradeoff is a little harsher ride.
    4DaFanS, Chikane, hafadaze and 3 others thanked this.
  15. 02SilverSiHB
    Jan 3, 2018
    2,248
    1,373
    Annapolis, MD
    2017 FK8
    true, I noticed it with prokit also...reminds me of the days of my 2005 STi when it was reallllly saggy in the rear :D
