Splashguards
  1. RedTouringMA
    RedTouringMA Senior Member
    Dec 15, 2015
    1,626
    597
    Western MA USA
    2016 Rallye Red Civic Touring
    Pics when you're done! :)
  2. CdnColin
    CdnColin Senior Member
    Sep 26, 2015
    933
    563
    Occupation:
    Retired
    Southern Ontario
    2O16 Civic Touring 'WOP', 2016 HRV EXL w/nav. 'Milano Red'
    Hi Manny, appreciate you participation. Looking at your 'thanked' percentage I'd say others do to.
  3. RedTouringMA
    Dec 15, 2015
    1,626
    597
    Western MA USA
    True, and he will learn a lot by the time he gets his new 2016 as well :D
  4. CE1_nobling
    CE1_nobling Senior Member
    Dec 21, 2015
    141
    94
    Occupation:
    Service Coordinator
    Spring,TX
    2016 Honda Civic LX 6sp , 1997 Honda Accord EX Wagon , 2005 Chevy Silverado 2500HD CrewCab 6.0
    Will do :thumbsup:
    RedTouringMA thanked this.
  5. back2civic
    back2civic Member
    Sep 21, 2015
    370Z
    What if you want to do the opposite? Removing the front splash guards? Can you re-use the self-tapping screws from the front splash guards?
    mechatune thanked this.
  6. bhorn
    bhorn Senior Member
    Nov 5, 2015
    632
    423
    Mobile, AL
    '16 Civic EX HS Sedan
    They are different. The screws that came with the splash guards have always-on washers, where the original ones did not. It will probably work fine, though. Just curious why you'd want to remove them. They keep dirt off the passenger door.
  7. RedTouringMA
    Dec 15, 2015
    1,626
    597
    Western MA USA
    Why would you want to take them off?
  8. back2civic
    back2civic Member
    Sep 21, 2015
    370Z
    I'd remove the front splash guards for the sporty look. Afterall, do you see any splash guards on the BMW 3/4-series?
  9. RedTouringMA
    Dec 15, 2015
    1,626
    597
    Western MA USA
    No clue, I never look at those, not my taste
    HondaMan thanked this.
  10. CiviOne0
    CiviOne0 Member
    Jan 3, 2016
    37
    Central Texas
    2008 Infiniti G37 2016 Honda Civic
    I added these splash guards on my car a few days after Christmas, just this past weekend we had non stop rain here and I noticed a big difference and more protection. I'd highly recommend them, plus they are easy to install as well. I still need to take pics of them on the car, cars been dirty past few days.
    RedTouringMA and twelver thanked this.
  11. CE1_nobling
    Dec 21, 2015
    141
    94
    Occupation:
    Service Coordinator
    Spring,TX
    Finally the rain stopped and I was able to install the splash guards.
    The wife likes them ...so all is good.
    I like the look.
    DannoMcK, Scion, CiviOne0 and 2 others thanked this.
  12. OP
    twelver
    twelver Member
    Dec 11, 2015
    2006 Civic
    I just got mine and put the two front ones on. They were straightforward. How do you remove the clip on the bottom of the car for the rear guards?? Im not sure how to get up under the car and take it out. Is it a screw on the other side? Do I need a jack to be able to see it?? Thanks.
  13. CiviOne0
    CiviOne0 Member
    Jan 3, 2016
    37
    Central Texas
    Looking sharp Ce1!!!
    twelver and CE1_nobling thanked this.
  14. Newflyer3
    Newflyer3 Senior Member
    Oct 7, 2015
    1,743
    1,027
    Calgary, AB
    So the trade off for your "sporty" looks is that you're not going to give a shit about the drivers behind you. Your location says you're from Canada so I'm assuming you get snow. In March, when that stuff melts and there's gravel all over, you'll just be throwing it all over behind you... God help the drivers behind you.
    You don't see BMW's or large d bag pickup trucks with splash guards because they don't come standard from the dealership and people don't want to drop another $150 on them.
  15. CE1_nobling
    Dec 21, 2015
    141
    94
    Occupation:
    Service Coordinator
    Spring,TX
    Twelver - You can do everything with the car on the ground...I suggest you invest in a stubby phillips head screwdriver if you do not already have one.
    The clip is easy to remove with a small flat blade screwdriver. Pry gently on the center part between the outside lip ,and it will pop out. Link for example of push pin type (http://tinyurl.com/splashguard-pin)
    Note : when reinserting the push pin to secure the splashguard , make sure the push pin goes inside the finder liner retainer hole and not just the painted bumper part. You might have to use two hands to do it. If you don't and just push it in, the guard will be loose.
    Hope this helps.
