SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos are now available to order!
  1. BoostedDreams
    BoostedDreams Senior Member
    Apr 15, 2018
    1,125
    660
    South East Florida
    Heisenburg
    2019 Type R, 2006 Mazda 6
    My understanding is that it will be roughly the same cost.
    Two Step Performance thanked this.
  2. OP
    Two Step Performance Senior Member
    Apr 24, 2018
    430
    658
    2017 Civic Si
    They are very slightly larger, the main difference is how SPEC has them interacting with eachother. (their "Proprietary" design)
    It's more a of a rattle noise. It's very strange the first time you notice it because it sounds like there is something loose in your transmission. The noise is not particularly loud but you hear it under low load / RPM situations.
    Yes, single mass. No details on weight yet, I hope to have that information from SPEC by the end of week, as they are on schedule to produce the first steel batch. Lighter than stock but not as light as the aluminum option.
    No details on price yet, I hope to have that information from SPEC by the end of week, as they are on schedule to produce the first steel batch. Due to high steel prices in today's market, it is likely the price will be very comparable to the aluminum wheel.
    BoostedDreams and davemarco thanked this.
  3. Matthyahuw
    Matthyahuw Senior Member
    Apr 15, 2018
    661
    348
    Valley of the Sun AZ
    Matthew
    2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
    Is it basically the same as a motorcycle's clutch rattle?
    I don't ride anymore, but my last bike was an older Suzuki GS1000 and that clutch pack rattled under zero load no matter what I did.
  4. OP
    Apr 24, 2018
    430
    658
    2017 Civic Si
    To be honest I am not familiar with motorcycle clutch pack rattle so I cannot comment on that.
  5. BoostedDreams
    Apr 15, 2018
    1,125
    660
    South East Florida
    Heisenburg
    Spec did reply to me when I inquired about the steel SMF.
    Here’s what I have:
    “I am thinking it will be a couple weeks. The OE is almost 32 lbs, and the aluminum is just about 11 lbs. So we were thinking about running the steel in the 23-25 lb range, which should offer some rate of rev benefit still, but with considerably less noise. No 1pc flywheel will be silent, but anything in the 20’s and in high carbon steel will be as close as it gets.”
    SPECTech
    WOPSiWOT, 10GenPearlSi and ApexEight thanked this.
  6. ApexEight
    ApexEight Senior Member
    Jul 13, 2018
    194
    71
    Atlanta, GA, USA
    Anthony
    2008 Honda Civic Si sedan
    Sounds perfect. I think Stage 3+ and the steel wheel will be a really good dual duty setup for people that daily their cars but also may take them on track or just drive spiritedly and are modded.
    BoostedDreams thanked this.
  7. davemarco
    davemarco Senior Member
    Jun 3, 2017
    2,269
    1,251
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    Just curious - is there a technical reason why a lightweight flywheel has to be single mass? Is there such a thing as a 17 lb dual mass flywheel? It sounds like that would combine the best of both worlds, if possible.
  8. ebatr24
    ebatr24 Senior Member
    Jan 20, 2018
    355
    229
    Oregon
    There is not much benefit to a dual mass flywheel for an experienced manual driver. Even though they make the car quieter and easier to drive, they're costly and not as durable in the long run. DMFs should have come only in the lower trim manual Civics, but Honda prefers to push the Si as a low priced sporty econobox. Since the OEM DMF has a price of $800 plus from Honda, I could only imagine the price of a lightened DMF if that existed.
  9. davemarco
    Jun 3, 2017
    2,269
    1,251
    New York
    I would argue that not having to hear gears rattling at idle is a fairly significant benefit. I don't have a whole lot of experience with SMF's, since all of my previous Hondas had DMF's, but I watched some Youtube videos of SMF's in the 13-17 lb range, and they all seem to makes some subjectively terrible noises at idle. It would be fine for a track car, but personally, I don't think that I'd want to deal with that on a DD.
    Also, I must again wonder how Honda has avoided any gear lash noise at idle with the SMF in the CTR. As SPEC had previously mentioned, SMF's supposedly will always have some noise at idle. The CTR's flywheel is also reported around 17 lbs, so it's not too far off from the 13 lb aluminum flywheels that we're seeing now. I'm admittedly a bit confused by the contradiction.
    10GenPearlSi thanked this.
  10. ebatr24
    Jan 20, 2018
    355
    229
    Oregon
    Most noise doesn't come at idle, it comes when you engage the clutch. Most of the time it is in the form of "chatter", I have an FX350 and the chatter is quite annoying to deal with. OEM flywheels are usually heavier so they absorb more shock and noise, the type R flywheel is not anywhere near as light as what Spec is offering. On a turbo car I wouldn't really want to go with such a light flywheel myself personally, I would rather go with the steel option they plan to offer. I had a lightweight flywheel in my past cars and never really had much of an audible difference.
  11. Ruskee
    Ruskee Senior Member
    Feb 20, 2017
    118
    '18 Si
    I've been very hesitant to settle on a clutch, even though my stock one is already slipping. Seems like SPEC Stage 1 with 23lb steel flywheel could be exactly what I need.
  12. BoostedDreams
    Apr 15, 2018
    1,125
    660
    South East Florida
    Heisenburg
    #27 BoostedDreams, Oct 2, 2018
    The stage 1 clutch only holds 236lbs of torque.
  13. Ruskee
    Feb 20, 2017
    118
    '18 Si
    2tone thanked this.
  14. ApexEight
    Jul 13, 2018
    194
    71
    Atlanta, GA, USA
    Anthony
    Something tells me the Stage 1 can't hold that much torque, that's a lot, but then 236 is very little.
  15. OP
    Apr 24, 2018
    430
    658
    2017 Civic Si
    This is the "normal / factory style" Stage 1 for the factory dual mass flywheel. I would not recommend this one.
    This is the "Proprietary" Stage 1, for use only with a matched SPEC single mass flywheel. It will indeed hold 342lbs at the flywheel, but remember this translates to about 290ft lbs at the wheels.
    For most people I am recommending the Proprietary Stage 2+, which will conservatively hold 380ft lbs at the wheels while still being very street friendly.
    See above. :)
    2tone, davemarco and ApexEight thanked this.
