SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos are now available to order!
  1. joshhjackson2112
    joshhjackson2112 Senior Member
    Jul 3, 2018
    290
    141
    Raleigh, North Carolina
    Josh
    18' SI
    So far I am planning to go with 2+.
    I have an aftermarket DP, CAI, and plan to run TSP Stage 2 Flex fuel.
    Should 2+ be fine for this?
    I plan to get the Drop in W1 turbo in 2020.
    Can 2+ handle the W1 or do I need to go ahead and go with 3+?
    I would like to get the 2+ for the street friendly reasons but will get the 3+ if I absolutely need to.
    I am about a month away from making this purchase.
    (New at Modding)
  2. OP
    Two Step Performance
    Two Step Performance Senior Member
    Apr 24, 2018
    382
    557
    2017 Civic Si
    Hi Josh,
    2+ will be fine. We are about to install a 2+ with our built engine and GTX2860 Gen II turbo. :thumbsup:
    joshhjackson2112 and BoostedDreams thanked this.
  3. AREA
    AREA HTX X GENZ @HTXXGENZ
    Sep 5, 2018
    342
    292
    Occupation:
    Structural Engineer
    Houston, TX
    95 hatch Drag car, K20Z3 00 Integra, 07 Civic SI sedan and 18 Civic SI coupe
    #168 AREA, Feb 18, 2019
    Happy to report no lockout with revised Spec stage 3 with aluminum flywheel and a fully adjusted pedal. Thanks @Two Step Performance I need tires now... Full boltons on E37 blend and your Stage 2 tune = 28lbs of boost lighting up tires even in third.
    Ps: stock clutch line, slave and master. Straight stock setup
    NoKz, Matthyahuw, 10GenPearlSi and 2 others thanked this.
  4. Matthyahuw
    Matthyahuw Senior Member
    Apr 15, 2018
    545
    276
    Valley of the Sun AZ
    Matthew
    2018 Agean Blue Civic Si Sedan
    thanks for the update @AREA
    AREA thanked this.
  5. AREA
    Sep 5, 2018
    342
    292
    Occupation:
    Structural Engineer
    Houston, TX
    No problem man! Just make sure whoever gets this to adjust your pedal at both points!
  6. 10GenPearlSi
    10GenPearlSi Old Man
    Jan 12, 2018
    427
    316
    Houston, Tx
    Bob
    2018 Pearl Si
    Did that make the clutch pedal higher than the brake pedal?
    AREA thanked this.
  7. AREA
    Sep 5, 2018
    342
    292
    Occupation:
    Structural Engineer
    Houston, TX
    #172 AREA, Feb 19, 2019
    Just checked and it does slightly!
    10GenPearlSi thanked this.
  8. BoostedDreams
    BoostedDreams Senior Member
    Apr 15, 2018
    612
    343
    South East Florida
    Heisenburg
    2018 Si Sedan
    Mine is higher and I still get locked out :(
  9. AREA
    Sep 5, 2018
    342
    292
    Occupation:
    Structural Engineer
    Houston, TX
    #174 AREA, Feb 19, 2019
    Wow what setup? I see 2+ but what flywheel
  10. BoostedDreams
    Apr 15, 2018
    612
    343
    South East Florida
    Heisenburg
    2018 Si Sedan
    Steel
  11. AREA
    Sep 5, 2018
    342
    292
    Occupation:
    Structural Engineer
    Houston, TX
    #176 AREA, Feb 20, 2019
    I have only heard of lockout in the steel flywheel. Anyone lockout on aluminum? I am on aluminum. I also have a 27Won Rmm and run Amsoil trans fluid
  12. charleswrivers
    charleswrivers Senior Member
    Nov 3, 2017
    1,937
    1,736
    Occupation:
    EMNC(SS)
    Kingsland
    Charles
    '14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
    @Two Step Performance FYI, I think your link on post 1 needs updating. I was trying to get more info and it gives me a 404 on your website.
  13. OP
    Apr 24, 2018
    382
    557
    2017 Civic Si
    Thank you, we have updated the link. :thumbsup:
    charleswrivers thanked this.
  14. NekoKinetics
    NekoKinetics Member
    Aug 7, 2017
    Chicago
    Neko
    2018 white civic si coupe. Mr2 Turbo
    Looking to pull the trigger on Spec 2+/Steel. Are people still having problems with lockouts?
