SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos are now available to order!
  1. Two Step Performance
    Two Step Performance Senior Member
    Apr 24, 2018
    427
    655
    2017 Civic Si
    #1 Two Step Performance, Sep 5, 2018
    SPEC Clutch Proprietary Clutch + Single Mass Flywheel Combos for the 2016+ Honda Civic are now available to order! These are expected to start shipping in about one week. With torque capacities from 342 to a whopping 659 ft lbs, we have an option for everyone!
    Check them out here: https://twostepperformance.com/search.php?search_query=spec proprietary&section=product
    These clutch kits use SPEC's proprietary design and must be paired with one of their flywheels. The result is a clutch kit that comfortably holds large amounts of torque, both on the track and the street. We have been testing the Stage 3+ setup, rated for 553 ft lbs and have found it to be very street friendly! (More so than the FX350 we previously had experience with)
    All current options are paired with SPEC's aluminum flywheel, which weighs in at 11.2lbs, just under 20lbs lighter than the factory dual mass flywheel! A bit of added drivetrain noise is present at low RPMS under low loads after shaving this much weigh off the flywheel. If you are particular sensitive to noises such as this, you may want to wait for the soon to be available steel option. The steel flywheel will be a bit heavier, sacrificing a small amount of performance for the reduction/elimination of drivetrain noise.
    No check engine lights or "misfire detection system" errors were encountered with this lightweight combo.
    We believe these kits are what the tenth gen Civic community has been looking for, and we are proud to offer them!
    BoostedDreams, Sly_Si, TypeR559 and 5 others thanked this.
  2. tehSteve
    tehSteve GrayBeard McGootch
    Sep 3, 2017
    587
    365
    NJ
    Si
    Which setup have you tested that didn't throw the CEL?
    Was the car flashed to Honda Factory Tune when testing for said CEL? (no tuning solution)
    How hard was the car pushed?
    Did you have to adjust the clutch pedal?
    repeet thanked this.
  3. repeet
    repeet Senior Member
    Jun 3, 2017
    601
    548
    Occupation:
    Retired
    Fort Mill, S.C.
    '17 Civic Si Sedan
    Was the " no check engine light" with a factory tune, or a performance tune?
  4. OP
    Apr 24, 2018
    427
    655
    2017 Civic Si
    It has not been tested on a completely un-tuned vehicle, however the misfire detection system disable that Ktuner allows was NOT utilized, and no error was present.
    The car has been pushed hard, but truth be told, nowhere near the 553 ft lbs this clutch is rated for.
    The clutch pedal did have to be adjusted. I would expect this with any performance clutch upgrade on this vehicle. It is a very quick and easy thing to do.
    See above. ^^ :)
  5. MGZ
    MGZ Senior Member
    Feb 18, 2016
    159
    91
    Bay Area, CA
    2017 Si Coupe, Previously 2016 EX-L (50k miles)
    Do you know if it is the same aluminum flywheel across all the options?
    Ie. If i got a stage 2 to start with, but ended up wanting a stage 3+ or higher, they'd all be compatible with the same flywheel replacement?
  6. OP
    Apr 24, 2018
    427
    655
    2017 Civic Si
    Yes, same flywheel. Thanks
  7. MGZ
    MGZ Senior Member
    Feb 18, 2016
    159
    91
    Bay Area, CA
    Thanks for confirming, dont know why more people aren't more excited about this! Those torque numbers look fantastic!
  8. OP
    Apr 24, 2018
    427
    655
    2017 Civic Si
    You should see the response we’ve seen in the various Facebook groups. :thumbsup:
  9. tehSteve
    Sep 3, 2017
    587
    365
    NJ
    Si
    These torque ratings are at the flywheel right?
    So realistically a Stage1 would be 290ish at the wheels, Stage2 about 340?
  10. OP
    Apr 24, 2018
    427
    655
    2017 Civic Si
    #10 Two Step Performance, Sep 5, 2018
    Yes those ratings are at the flywheel, I’d add about 15% to roughly convert from wheel torque.
  11. Matthyahuw
    Matthyahuw Senior Member
    Apr 15, 2018
    661
    347
    Valley of the Sun AZ
    Matthew
    2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
    Thanks for these. Good to have more options.
    Two Step Performance thanked this.
  12. Hondanickx
    Hondanickx Senior Member
    Jun 10, 2018
    327
    152
    Belgium
    Nick
    1998 civic hatch , 2018 White civic sedan
    #12 Hondanickx, Sep 6, 2018
    So are these clutch discs bigger then the factory disc ?Cause they hold so much more torque ,there's more into it then just a replacement clutch .
    @ Two Step Performance did you figured out why your clutch didn't gave a cell and other do ? Is it in the flywheel weight or design or ...?
  13. davemarco
    davemarco Senior Member
    Jun 3, 2017
    2,230
    1,241
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    Could you describe the drivetrain noise that you referenced in your write-up? Is it a chatter at idle, or certain vibrations? Would be hesitant to buy without seeing a video of it, to better understand whether it would be tolerable or not.
  14. davemarco
    Jun 3, 2017
    2,230
    1,241
    New York
    Will the steel flywheel option still be a single mass? What is the targeted weight?
  15. joshhjackson2112
    joshhjackson2112 Senior Member
    Jul 3, 2018
    624
    362
    Raleigh, North Carolina
    Josh
    18' SI
    How much more will the steel flywheel option cost?
