Spec Clutch Install Issues
  1. hpbyhermann
    hpbyhermann Senior Member
    May 14, 2019
    489
    539
    Edgewater Maryland
    Hermann
    2019 Championship white Type R #25133, 09' Civic SI sedan, black 2013 Boss 302 Laguna Seca, 1993 Mustang Cobra, 2004 Mustang Cobra
    You aren't understanding what I'm saying...define "defective clutch" I'm a shop owner and master mechanic. From the symptoms the OP was describing it sounds like the pressure plate wasn't fully disengaging the clutch disc making shifting extremely difficult. The next step is to find out why this is happening. There might be a need for an adjustable throw out bearing. Check the stack height of the assembled clutch/pressure plate assembly and compare it to the original setup. Measure from the mating surface on the block where the transmission mates up to the flats on the fingers of the pressure plate where the throw out bearing presses. This measurement should point you in the right direction to solve the issue. This is something that should be checked on any replacement clutch, and more so on aftermarket replacements. I have to do this frequently on cars that convert to dual and triple disk clutch setups.
  2. bbp
    bbp Member
    Apr 1, 2019
    NY
    Civic
    It's the defective pressure plate in both of my cases that does not fully disengage.
    There shouldn't be any need for an adjustable throw out bearing because everything provided should work 100% if it's not defective.
    If it doesn't work and pedal adjustment does not solve the issue, there is nothing else to adjust and the OP should return the defective parts while he can.
  3. OP
    CXRB17
    CXRB17 Senior Member
    May 25, 2017
    195
    110
    Chicagoland, Illinois
    '16 Civic Sedan LX, '17 CTR (PA Signed in WI, ETA 5/31-6/7, Blue)
    679DEA3A-4A63-423D-B362-0B780E8F6869.jpeg 83C7CA0F-FC42-443F-A3D7-86E4D8DCE162.jpeg
    So the installer and spec spoke today. Seems that the clutch was manufactured improperly.
    Working through MAP to get a refund. They’re giving me some pushback but at the end of the day I think it’ll get taken care of.
    Now I’m debating getting a new OEM clutchplate while they’re in there.
  4. OP
    CXRB17
    May 25, 2017
    195
    110
    Yeah I’ve learned that the hard way here. Working to get a refund.
  5. Caestus
    Caestus Senior Member
    Jun 22, 2019
    268
    129
    Miami Florida
    Jeremiah
    19 Civic Type R
    I hope it all works out for you.
  6. Arcam
    Arcam Senior Member
    Feb 15, 2019
    88
    26
    UK
    Eddie
    2018 CTR
    I hope that PP did not look like that when it was first fitted, if it did the dealer who did the job should have questioned it for sure!
    Who is going to pay the labour charge?
  7. turbociv910
    turbociv910 Senior Member
    Jun 25, 2019
    130
    112
    wilmington nc
    taylor
    19 SI, 99 ex b20v
    #37 turbociv910, Sep 6, 2019
    Getting pushback on a defective product.. shame.
    As a technician, i would have questioned the "fingers" once tightened down. Most are relatively "flat".. those are definitely further in and leaves Less travel room for movement/disengagement.
  8. hpbyhermann
    May 14, 2019
    489
    539
    Edgewater Maryland
    Hermann
    Absolutely agree, that is definitely a HUGE red flag!!
  9. OP
    CXRB17
    May 25, 2017
    195
    110
    I’m assuming it did look like this when installed considering the issues popped up right away.
    I was quoted one additional hour for labor beyond what the warranty was covering for the separate issue. I will not be paying more than that.
  10. OP
    CXRB17
    May 25, 2017
    195
    110
    This information is frustrating to me. Appreciate it, at least I can use this if they start and argue labor fees.
  11. OP
    CXRB17
    May 25, 2017
    195
    110
    Here’s the morning update.
    Spec called and after they saw the images their whole attitude changed.
    They’re overnighting a new pressure plate and want to hear back that the issue is resolved.
  12. Arcam
    Arcam Senior Member
    Feb 15, 2019
    88
    26
    UK
    Eddie
    2018 CTR
    Hopefully they will pick up the labour charge, don't know about the US but in the UK the retailer who sold the part is responsible but like I said before, the garage who first fitted it have to take heat on this as it was obvious to me the PP was not correct.
  13. OP
    CXRB17
    May 25, 2017
    195
    110
    Man, what doesn’t the UK do better than the US. Here in the states there’s nothing legally stated about labor. Thankfully my shop has been understanding and with this news from you guys, I’m sure they’ll be even more so moving forward.
  14. turbociv910
    Jun 25, 2019
    130
    112
    wilmington nc
    taylor
    19 SI, 99 ex b20v
    how is a pressure plate installed if the bolts are loose? easy check for relase issues if to lift the car, put the car in gear, push clutch and have a mate try and turn the wheels by hand.
  15. OP
    CXRB17
    May 25, 2017
    195
    110
    Who said anything about loose bolts?
    Maybe I missed something. I’m not following what you’re saying here.
