Spare tire kit on hondapartsnetwork
bigoldglock
Chicago
2017 Civic Si Sedan, 2013 Honda Odysessy
There's a guy from the state's that bought the kit and installed in his SI. He has a video on YouTube.
The youtube video with the spare is mine in case anyone has questions, i think the compromise of putting together the assorted parts gets the job done with minimal expense. I still have room under the new mat to keep the tire inflator as well.
It is still irritating that honda didnt include a spare to begin with. Im happy with what i have going on in the trunk as is in the video.
jeremiah
Jeremiah
Northern California
2017 Honda Civic Si coupe, 1999 Lexus Gs300
Thank you for sharing, my spare tire kit is coming in this Monday.
Ordered all the necessary items to make it look oem (spacers, cargo cover thing, etc)
And agreed, sadly most manufacturers nowdays dont include a spare tire kit...its that damn fix a flat crap.
Now I can have peace of mind in case I get unlucky, I can change it myself.
I save my tows for engine trouble etc.
squareback
Kansas
2017 WOP Si sedan, plus a bunch of Hondas and a GMC tow vehicle
Blame the American public. When most people shop for a car, the cubic feet of trunk space is one statistic they look at. The spare tire kit uses almost 2 cubic feet of space, and that would be enough to take it lower than Honda wants. So it is because Honda made the center exhaust and doesn't want to put the spare in there, but that's really the fault of the general car-buying public.
neteng101
NJ
2017 Honda Civic Hatchback Sport Touring
The more I see the more I think its a mistake Honda just didn't go with twin exhaust outlets, one on each side - on the Si and Sport/Touring hatchbacks. Would have avoided so many issues not having the center exhaust, and the spare tire in my Sport Touring hatchback doesn't have the best solution either, its just a raised cover with foam blocks under the sides. Only thing useful about it is that I can stuff some tools and other stuff easily under and hide it all away. Looks like the Si in Canada is stuck with the same sort of half assed solution for the spare tire cause of the center exhaust.
squareback
Kansas
Couldn't agree more. I'm not a huge fan of the center outlet anyway, and the lack of a spare tire because of it is just salt in the wound.
thetwoeddies
Eddie
Boston
2017 Civic Si Coupe
Yeah but it has definitive-enough firmness to it that I don't think the mat has. I think there might be visible and tangible bumps and dips with the mat, where the foam meets the tire. But in either case, I do hope this works out, and look forward to pics/report when it's done!
Thanks for laying out the pros and cons earlier. I find myself in the same predicament. If you choose the full spare option would you secure it in the Trunk Spare well or just in the trunk cargo space. Thanks again.
jeremiah
Jeremiah
Northern California
Just installed the spare tire kit yesterday.
Spacers, new floor cover, went to my local tire shop to get the tire installed on the wheel, locking nut, tool foam thing, etc.
All I need now is a lug wrench and jack.
Photos to come later.
dmitri
dmitri
Atlanta, GA
2017 Civic Si sedan
I would probably just put it in the trunk (on top of trunk floor/cover), off to a side, to maximize the available contiguous storage space. Sure it would save a couple inches in height if put in the middle, but then I'd have to what, cut a circle in the middle of the trunk floor cover? :) Plus, less contiguous space would interfere with actually using the trunk (fitting suitcases, etc.), making the space behind the wheel and to the sides of it nearly unusable.
zroger73
United States
2019 MX-5 Miata GT-S, 2021 Ridgeline RTL-E
Cadillac was one step ahead of you. :D
Honda Civic 10th gen Spare tire kit on hondapartsnetwork cadillac-seville-1985-7
squareback
Kansas
I've finished the rough install of my DIY spare tire kit. I used the dense pink foam insulation board that's available at home improvement stores to raise the floor just like the OEM kit does. The tools are wrapped in bubble wrap and tuck just behind the spare tire. The stock carpet doesn't cover the sides, but you could either live with it or use an OEM rubber trunk mat like I did. You can pick up a spare tire and kit from some other Honda product for cheap, and this whole project should easily come in for under $200 even with the trunk mat. Much better than the $500 you'd have to spend for the Si-specific one.
