nicky8668
- Nick
- Apr 19, 2019
- 15
- 88
- 105
- Pennsylvania
- 2019 Honda Civic Sport Sedan
Hi All
I have had my 10th sport sedan 6MT for a week now. I put about 500 miles on it and I'm so disappointed with the shift quality. Rough into 1st, notchy 1-3, clunky 3-4. Impossible get back to 1st unless I'm almost 100% dead stop. I found many folks on this forum also have the same issue, si, type R, EX-T. I think I eventually figured out what's wrong. It's CLUTCH DRAGGING!
What gets me suspect it's the clutch dragging is the following symptoms.
#1. floor the clutch, immediately shift into any gears, rough
#2. floor the clutch, wait 5-10 sec the shift into any gears, smooth
#3. Do #1, keep clutch in, back to N, then shift to any gear is smooth
#4. After #3, back to N, let go clutch, floor clutch again, immediately shift into any gears, rough
It looks like the input shaft still rotates for few sec before coming to a stop. If you shift when its still rotating, the shift is rough
Those symptoms tell me 2 possibilities:
1) Bad synchro on all gears (which is extremely unlikely to have bad synchro on ever gear in a 500 miles vehicle)
2) Clutch dragging, disengagement issue
So, I went ahead and adjust those two nuts on the clutch pedal and CMC. Two thread counterclockwise, tighten everything. And drive around the block.
Men, it feels like a different car. Extremely smooth and confident shift into any gear. I can floor the clutch and shift to 1st gear while going 40mph (of course don't let go off the clutch).
I think most people feel it gets better over time is because the clutch gets worn over time and you don't feel that much dragging. And other premium gear oils are obviously thicker than honda genuine MTF and they probably will stop the dragging faster, especially when the car warms up and gear oil gets thinner.
Try those if you have rough shift or grind problem, especially 1st to 2nd. This solved my problem. Hope it solves yours too. Don't think it will break in, it can damage your synchro over time. You don't know if it would be your synchro or clutch get worn first.
Let me know if this helps your problem.
