Solid rear camber kit for 18' HB Sport?
Abhorsen
18' FK7
Hey guys,
Purchased the Buddy Club Sport spec coilovers and they should be arriving soon, going to check out Evasive Motorsports for the install. Figured I would need a rear camber kit (I assume front isn't needed) so that the tires don't get worn out unevenly. Any of you guys have recommendations for a solid rear camber kit?
xjoshuax89
Josh
Maryland
I went with Ktuned
Get the Eibach kit that is on clearance right now. It is a repackaged SPC kit and only $130.
Link to where the kit can be purchased?
Eibach is selling it at the discounted price. There is another thread here with details.
timmychan
Timmy
Houston,Tx
2018 Honda Civic Hatchback sport
Hey guys,
I keep seeing everyone say they need rear camber but no one mention needing front camber kit. Can someone explain or did Honda decide to put adjustable front camber on the 10thgencivic?
maaaaackle
Socal
Sport Hatch 6MT
Usually coilovers come with a camber plate on the top for the fronts camber adjustment.
timmychan
Timmy
Houston,Tx
I know coilovers comes with camber plate. I mean for people who are lowering on springs and stock shocks.
L8apex
Southern Cali
2018 SGP Sport
There is no way to adjust the front camber on stock shocks.
There is “some” adjustment on the OEM front strut mount, but you have to remove the locating stud. The 3 bolt holes for the top strut mount are slotted, but it’s only a tiny bit of adjustment available. 0.5 degree max if I remember correctly.
Abhorsen
18' FK7
And is there any difference between camber kits? I bought a pretty decent set of coilovers and I’m basically looking for a decent camber kit as well. If it means spending a bit more I won’t mind at all.
Thanks guys,
