procivic
- Jan 29, 2016
- 123
- 1,524
- 1,136
- Ventura, California
- Website
- www.procivic.com
- 2017 Civic Si Sedan, Others
In my opinion, this is far and away the best oil cooler kit on the market, for the 1.5T or Type R. The oil cooler unit placement is perfect for maximum airflow and no obstructions. No trimming or elimination of factory vents or brake ducts either. Simplest design and install possible and relocates your oil filter for easier future oil changes. Plus, all the hardware is high-grade and built to last!
I attached a PDF file of the FK8 CTR SiriMoto oil cooler install instructions (file attached at bottom of this post). If you look through all the steps, you can see the great attention to detail and high quality engineering that was put into each component on this kit. It even comes with a specialized 10AN thread adapter with a unique hex nut on it JUST so you can make sure your oil filter pedestal base is torqued 100% correct (better than the OEM filter which normally is just torqued by hand). It includes a nice black 10AN wrench too!
Forum discounts are available! Product page is here: https://www.procivic.com/p/m/civic/sirimoto-engine-oil-cooler-kit.html
Here are some quick specs on the kit, but follow the product link above post for even more details.
One more interesting thing: here's a spotlight video of one of the main components of the kit, the Oil Filter Take-Off and Pedestal. Has some very innovative design features.
- Pre-Assembled -10AN hoses.
- -10AN ORB to Male Port Adapter Fittings.
- 90-degree -10AN Female Union.
- All aluminum 19-Row Oil Cooler Core with Mounting Brackets. Coated in a silver finish for corrosion resistance.
- Core Size: 285mm x 150mm (11.2" x 5.9").
- Core Thickness: 50mm (1.96").
- Sirimoto Oil Filter Take-Off.
- SiriMoto Oil Filter Pedestal and Bracket.
- SiriMoto Black Fender Washers with Rubber Nuts.
- Silver Zinc Coated Flanged Hex Head Hardware.
- -10AN Aluminum Wrench and 3mm Ball-End Hex Key.
- Blue Thread Locker.
- Fluid Capacity Increase: ~1 Qt.
- Optional Oil Filter: PLM Style (PCX filter not recommended due to space constraints).
