SiriMoto E85 Flex Fuel Kit for the FK8 Civic Type R!
  1. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    503
    303
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX5
    Can you elaborate on which value to change and where to change it to make the Innovate gauge read correctly. Thanks.
  2. PhAzE7
    PhAzE7 Senior Member
    Mar 28, 2018
    81
    40
    New York
    ‘18 Civic Type R, ‘09 Acura TSX DD
    The innovative gauge reads correctly. Don’t change any values as it seems to read correctly from the default values in the tune.
    If you click calibration then click ethanol and hit F1, it will show you what values we are supposed to change.
  3. boosted180sx
    boosted180sx Senior Member
    Mar 27, 2017
    2,848
    2,297
    torrance, ca
    2017 CTR, 2019 370Z Nismo, '16 ILX
    the innovate gauge i'm sure is reading correctly. It's just not displayed correctly onto the hondata app.
    The default value is 0.4v = 0%, and 4.8v = 100%. Just don't mess with that value.
    Meat Hammer thanked this.
  4. boosted180sx
    Mar 27, 2017
    2,848
    2,297
    torrance, ca
    hondata emailed me back and said to use the factory values. never heard of a sensor being 0.4-4.8v but :dunno:. It works and that's all that matters.
    Time to gather some data for E28 that i'm currently at.
  5. toddrhodes
    toddrhodes Senior Member
    May 21, 2018
    672
    713
    Occupation:
    Product Manager
    Indiana
    Todd
    '18 CTR #16979, '18 Odyssey
    #140 toddrhodes, May 20, 2019
    I'd be down for sharing a log if you would want to. I have logs of both pure 93 octane and at E30 and to me? E30 looks much better. Fuel pump duty cycle, and duty cycle commanded are closer together on E30, timing is higher, and knock is at zero for the entire run where the 93 pull had slight amounts of knock and subsequent knock retard. Boost was lower on E30 but until I can get it on a dyno (and it'll be tricky to dyno 93 vs E30, but I think we can figure it out, but I'd swear it feels faster on E30 than with 93, across the board.
    Edit - and using the very unscientific method of using log timestamps, Excel, and VSS data, E30 is faster. Not by a ton, but it is.
  6. PrisonerOfDoom
    PrisonerOfDoom Senior Member
    Aug 22, 2017
    139
    103
    Occupation:
    CBD Oil
    Thornton, CO
    Dustin
    '17 Type R #3166, '04 IS300, '01 Tacoma
    Thanks for letting us know what they said. I still need to find the time to install my kit. I saw your install pics with the Mishimoto catch can and it looks really clean. I'd like to know what your logs look like if you don't mind sharing. I'm curious to see what the fueling looks like. Do you have full bolt-ons?
  7. PrisonerOfDoom
    Aug 22, 2017
    139
    103
    Occupation:
    CBD Oil
    Thornton, CO
    Dustin
    Did you by chance have Derek look over your logs and confirm what we were seeing?
  8. toddrhodes
    May 21, 2018
    672
    713
    Occupation:
    Product Manager
    Indiana
    Todd
    I did, haven't heard back yet.
    PrisonerOfDoom thanked this.
  9. toddrhodes
    May 21, 2018
    672
    713
    Occupation:
    Product Manager
    Indiana
    Todd
    Just for a little extra data, comparing my logs:
    30-70 is about .15 seconds faster on E30 than on 93
    50-80 is .45 seconds faster on E30 than on 93 (2.73s vs 3.18s). That's more than noticeable.
    Again, this is just using timestamps in the logs and equal VSS readings on both logs for comparison. It was warmer for the E30 logs but at those speeds, traction shouldn't be an issue.
  10. FlexRex
    FlexRex Senior Member
    May 13, 2019
    57
    Arizona
    WRX and M5
    Can you use virtual dyno or something similar to plot it and look at a graph.
  11. boosted180sx
    Mar 27, 2017
    2,848
    2,297
    torrance, ca
    Thanks. I took my sweet time routing wires so it's virtually hidden and making that bracket. Friend had some left over S2000 J's racing diffuser bracket that worked so we just bent it and made a hole to bolt it in. I didn't want to bend the catch can bracket nor the flex fuel bracket. I must say I am pretty satisfied with the way the bay looks.
    As for power mods, I am only running a the sequence exhaust and an afe intake. Still on stock cats and stock front pipe. I haven't went out on a drive yet so no data yet. I wanted to figure out the E values being different on the gauge and the app before i start gathering data.
    sweet. you think you can pm me with the datalog? I'd be curious to see some data and would be nice to have something to compare it to mine since i'm blending with 91 and not 93.
    Still haven't pushed the car yet but it's probably going to a big jump coming from 91 octane.
  12. CBPtypeRgrunt
    CBPtypeRgrunt Member
    Apr 6, 2019
    West
    18’ FK8, AP1 S2000, F-150, YZF-R6
    Anyone get a custom tune on e40?
  13. toddrhodes
    May 21, 2018
    672
    713
    Occupation:
    Product Manager
    Indiana
    Todd
    #148 toddrhodes, May 20, 2019
    Take this with a healthy grain of salt as far as actual numbers go - closest car I could choose was a 2015 Civic Si. I plugged in what I think is the FK8 FD and my actual tire height. Unfortunately the 93 octane run (red lines) had some 4th gear action as well so that's why the graph gets all weird, I think. But it's a decent visual:
    pic removed to avoid confusion
  14. FlexRex
    May 13, 2019
    57
    Arizona
    WRX and M5
    You can make custom cars as long as you know your cars details to enter.
    I would at least make sure the gearing is correct for the civic you used and if not change it accordingly. I doubt oem gearing is same on 2015 si and fk8. (Among many other things.)
    Once you get that down its pretty accurate.. i can make my plots on same day point over basically. Custom tune e50 green and e60 red. Different tuners.
  15. toddrhodes
    May 21, 2018
    672
    713
    Occupation:
    Product Manager
    Indiana
    Todd
    #150 toddrhodes, May 20, 2019
    Here we go, this is with the correct gears, drag coefficient, and weight updated. Closer, this time around:
    Edit - just updated the pic. It looked a little off to me and I realized I didn't have an occupant weight in the E30 run. I'll get the hang of it, promise.
