SiriMoto E85 Flex Fuel Kit for the FK8 Civic Type R!
  1. procivic
    procivic Senior Member
    Jan 29, 2016
    1,144
    956
    Ventura, California
    2017 Civic Si Sedan, 2017 Civic EXT Sedan (manual), 2014 Civic Si Sedan, Others
    #1 procivic, Apr 17, 2019
    When the Type R first came out, we were unsure if it would have similar power modification potential compared to the 1.5T engine. Well, I'm happy to say that those days are gone! With the Hondata FlashPro FK8 Civic Type R Flex Fuel software update and this new SiriMoto E85 Flex Fuel Kit, your Type R will see 65+ hp and 70+ lb-ft of torque using just the Hondata Base Map and some E85 fuel (at about E40 concentration).
    Here are some key takeaways for the Type R version of this kit:
    • Available Base Calibrations will provide peak performance at ~40% ethanol (E40) concentrations.
    • The FlashPro has a specific safety strategy for the Type R: boost will decrease as ethanol concentrations surpass 30% (E30) mixtures.
    • Boost is reduced in this manner because the stock High Pressure Direct Injection Fuel Pump cannot supply the necessary fuel volume for full boost at E40. Even with the reduced boost, your Type R will make more power running E40 compared to E30.
    Key general features of the SiriMoto E85 Flex Fuel Kits:
    • Allows you to run E85 fuel, and mix it with regular pump gas. Your gas tank is not required to just have all E85 fuel in it after installing this kit (hence the name Flex Fuel). The Hondata FlashPro will automatically adjust your tune on the fly as needed for your current fuel mixture.
    • Potential for huge power/torque gain.
    • Helps to spool a turbo earlier and faster.
    • Allows the engine (and turbo) to operate considerably cooler.
    • Enables the ECU to dynamically adjust your tune, for a given amount of ethanol percentage.
    • Best bang for your buck power adder.
    • Easily monitor your E85 / Ethanol-Percentage level with the included Innovate digital gauge.
    • You can choose to run regular gasoline and only pump E85 when you desire more power/torque.
    • This kit was thoroughly tested and designed with very reliable components.
    • Easy to install and features pre-assembled fuel lines to plumb the Ethanol Sensor.
    • Comes with comprehensive installation instructions.
    • Covered by a 1 Year Limited Warranty.
    • Custom SiriMoto Flex Fuel Badge included with every kit.
    • Includes everything you need for a complete installation.Plug-and-Play (PnP) solution, does not require any splicing of wires.
    • Premium Chasiss Harness constructed with:
      • Tefzel Wiring
      • Deutsch Connector
      • Flame-Retardant Nylon Sleeve
    • Sturdy Ethanol Content Sensor Bracket for lifetime reliability.
    • Includes Gauge Pod to easily mount the Innovate digital gauge.
    For more information on this kit and/or to purchase, follow this link: https://www.procivic.com/p/m/civic/sirimoto-e85-flex-fuel-kit.html
    For the Power Package that includes a Hondata FlashPro, see here: https://www.procivic.com/p/m/civic/sirimoto-hondata-flashpro-e85-flex-fuel-power-package.html
    Please keep in mind, this product is not designed for public highway or street use, and is only legal for formally sanctioned race use on a racing vehicle that may never be used on a public highway or street.
    As always, let us know if you have any questions!
  2. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    510
    308
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX5
    :thumbsup: Outstanding! Decisions, decisions....
    [email protected] thanked this.
  3. PhAzE7
    PhAzE7 Senior Member
    Mar 28, 2018
    81
    40
    New York
    ‘18 Civic Type R, ‘09 Acura TSX DD
    Big day for the FK8 and this is just awesome!
    Excited for the future of this platform.
    ixdime and [email protected] thanked this.
  4. Streetthrowback
    Streetthrowback Senior Member
    Mar 13, 2019
    70
    26
    Nyc
    Francisco
    2019 Honda civic type r
    I wonder if ktuner will have something like this, if not I may have to switch
    17CivicTypeR_Brian thanked this.
  5. Fk8_Santi
    Fk8_Santi Member
    Apr 26, 2018
    26
    Arkansas
    Julian
    2018 Civic Type R #11903
    Already ordered mine! Hope with my full bolt ons it’ll hit 400whp
  6. Ihave0time
    Ihave0time Member
    Feb 17, 2019
    NC
    Jaws
    ‘19 CTR
    Guess Ill be ordering this when i get my hondata
    17CivicTypeR_Brian and procivic thanked this.
  7. Streetthrowback
    Mar 13, 2019
    70
    26
    Nyc
    Francisco
    Does anyone know if you already have a ktuner v2 and want to make the transition over to hondata flashpro do you still need to get your ecu jailbroken if you already did with ktuner?
  8. 02SilverSiHB
    02SilverSiHB Senior Member
    Jan 3, 2018
    1,758
    1,131
    Pasadena, MD
    2017 FK8
    I just switched over to hondata on Monday from ktuner...I did not need another jail break...worked flawlessly for me
    Meat Hammer, procivic, FK8_K20c1 and 3 others thanked this.
  9. Streetthrowback
    Mar 13, 2019
    70
    26
    Nyc
    Francisco
    Great to know!
    02SilverSiHB thanked this.
  10. 06S2k07Si
    06S2k07Si Senior Member
    Feb 13, 2018
    207
    128
    Wisconsin
    Brian
    2006 S2000 2007 Civic Si 2008 TSX 2013 CB1000R 2018 Civic Type R 12063
  11. Joshua122303
    Joshua122303 New Member
    Mar 24, 2019
    Dalton , Georgia
    Gabriel
    2019 CTR #20799 SGP
    I just ordered mine
    procivic and 02SilverSiHB thanked this.
  12. 02SilverSiHB
    Jan 3, 2018
    1,758
    1,131
    Pasadena, MD
    2017 FK8
    I keep looking at this thread...so freaking tempting. Great price and love the plug play setup
    boosted180sx and bobafettm thanked this.
  13. Ghostype_R
    Ghostype_R Senior Member
    Sep 27, 2016
    54
    68
    south New Mexico
    Turbo Fr-s, Rx8 -ls2 , 2017 camaro ss1le, 2017 Civic type R #1353
    I believe any kit will work. The only issue I see is the mounting bracket for the flex fuel sensor would have to be made.
  14. 06S2k07Si
    Feb 13, 2018
    207
    128
    Wisconsin
    Brian
    I'm not I'm not asking if any kit will work, I'm simply asking to be able to purchase this kit from them without the supplied gauge or an option for another one of my choice.
    Ghostype_R thanked this.
  15. FK8_K20c1
    FK8_K20c1 HONDA The Power of Earth Dreams Technology!
    Jan 12, 2018
    640
    357
    Occupation:
    Engineer
    Indiana
    MKV R32, FK8 Type R
    Nearest Ethanol station 53 minutes. FML
