Simple Cooling Mods for the Track Without Voiding Warranty?
  1. ixdime
    ixdime Member
    Sep 25, 2018
    Tallahassee, FL
    Josh
    2006 Mitsubishi Lancer Evolution
    Hey everyone, I’m looking to buy a 2019 CTR here soon. I’ve been researching the car for awhile and it seems like if you are going to be tracking the car, you are going to run into some overheating issues (I live in FL). I was hoping the CTR could handle track work in 100% stock form while still maintaining my factory warranty. Are there any actually effective cooling mods that would not raise a brow at the dealership OR are easily reversible? For instance, if I blanketed the turbo, wrapped the DP, and installed the better flowing grille, would this be sufficient to get me through a 20 minute session in 90F Florida weather? Or am I dreaming here??
  2. alejandroads123
    alejandroads123 Senior Member
    Apr 30, 2018
    671
    241
    Daniel
    Civic type R
    I live in Florida too, and I have a couple mods: Mishimoto Intercooler ( It came with charge pipes) Turbo blanket , GRP downpipe with downpipe blanket , Inlet turbocharger heat wrapped , Inlet turbocharger thermal gasket , charge pipes heat wrapped bottom of intake box heat wrapped. Whit all this mods I got a great improvement , Florida is terrible with heat soak. I will attached some pics.
    Some people has experimented also high ECT temperatures, and the solution for that is improve the air flow trough the radiator, some of us replace the front grill.
    Depends of the dealer , some dealer does't have any problem with mods, and other does. Basically if they can prove the parts you installed is causing the issue it void the warranty. But some dealers are very strict.
    ixdime and Fk8tjt thanked this.
  3. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    1,580
    1,108
    Occupation:
    Car Driver
    Ridiculosaurus
    1.5T Civic, CTR, MX-5, Fit
    #3 TypeSiR, Apr 3, 2019
    Without modding, you can try turning on the heater to 3/4 setting and fan at full blast to bleed off some heat during track sessions. Obviously, turn the louvers away from your face/body. Here’s a good read:
    https://www.thetruthaboutcars.com/2017/11/issues-civic-type-r-honda-fixing-one/
    Le0L111 and ixdime thanked this.
  4. EnjoyDriving
    EnjoyDriving Senior Member
    Sep 3, 2018
    546
    134
    Minnesota
    2018 CW FK8
    there is a member on here got voided warranty coz of his turbo blanket, surprising right, so do take off the blanket for any dealer services if u dun wanna risk it.
  5. .grimace
    .grimace Senior Member
    Nov 9, 2017
    1,219
    814
    Occupation:
    Web Design
    Reno, NV
    Byron
    2017 CTR, 2014 911 4S, 2019 Range Rover, 2018 F-JuanFitty
    I came to post exactly this
  6. OP
    ixdime
    ixdime Member
    Sep 25, 2018
    Tallahassee, FL
    Josh
    Yeah I heard this as well! Thanks for the reminder.
    I know it’s not exactly “easy” to remove, but definitely can be removed with no trace
  7. OP
    ixdime
    ixdime Member
    Sep 25, 2018
    Tallahassee, FL
    Josh
    Thanks for the pics. I do know there is some resolving of this issue with a couple mods but intercoolers/intake I would like to avoid. It seems that most of your modifications are heat wrapped items though. Are you still on the the stock radiator and oil cooler? And did you modify your grill?
  8. boosted180sx
    boosted180sx Senior Member
    Mar 27, 2017
    3,711
    3,050
    torrance, ca
    2017 CTR, 2019 370Z Nismo, '16 ILX
    front grill
    oil cooler
    intercooler
    would probably be the top 3 mods i'd do cooling wise.
    BoostSeason thanked this.
  9. alejandroads123
    Apr 30, 2018
    671
    241
    Daniel
    Civic type R
    I'm still stock radiator and no oil cooler at the moment. But I'm planing to change the front grill and maybe oil cooler in the future.
