Hondanickx
- Nick
- Jun 10, 2018
- 61
- 1,040
- 788
- Belgium
- 1998 civic hatch , 2018 civic sedan 1.5T
- Build Thread
- Link
- Vehicle Showcase
I've been toying around with the Si airbox and found several interesting differences.
The Si Airbox has a smoother air path towards the MAF Housing .The MAF sensor hole size on the SI is 31mm and 26mm on the non Si .The mounting holes center distance is also different between the two.49mm for the Non Si airbox and 52mm for the Si airbox.
A better air guidance towards the maf Housing on the SI airbox .Also seen is the big difference of the air intake .The Si has a Oval air intake of 60x80mm ,the Non Si has a air intake of 60mm round.
The Si Air intake is 33% bigger in surface area !
The Si Airbox has more clearance inside the airbox for better airflow .There're no air guides in the Si airbox and it has a better flow of air.
Big difference between the two air intakes.The Si has a large and short intake path.
Longer and smaller air intake path for the Non Si.
I've also added the dimensions of the Si and Non Si oem MAF housings.
The intake side of the Si is bigger then non si.
60mm Vs 57mm which equals to aprox. +10% in surface area!
Overal the Si Airbox would be a great upgrade for any non Si owners .
The airflow towards the filter is impoved everywhere ,and the intake side from the MAF housing is also slightly bigger.
Only thing that needs to be done is modify the MAF sensor hole and mounting holes.
MAF sensor hole needs a bushing to make the hole smaller.The mounting holes need to be drilled out and receive new smaller threaded bushing.
I'm 90% done with that just waiting for some parts to finish it.
