d1zguy
- Apr 6, 2017
- 23
- 769
- 369
- VA
- 19' Mustang GT Premium
Hi All,
Thought I would start this and upload calibrations for input and just general conversation.
I've started of with Starter 19.5 base tune.
With following changes
1. Setup BBG - 1st, 2nd-6th.
2. IAT corrections per ktuner for more stable knock control
4. All quick adjustments stock with boost ramp-up disabled
5. Anti-lag set at 3500 RPM with -6.5 degrees pulled (Builds about 7PSI of boost) 2step at 4000rpm
6. NLS set at 4350RPM
7. Early Spool
8. Target 15.1 afr low load at ECT >176c
9. 800 RPM idle
7. All other settings are same as the base 19.5 ktuner tune
Building this tune to go on the track (circuit or auto-x not drag) with. Was not a fan of the stock tune (throttle pullback) or any of the starter tunes with the massive tq peaks at 3000-4000 rpm especially on my weak stock clutch. Don't like the feel of a car getting SLOWER or not increasing the rate of acceleration as the rpm's increase
Another observation is that the factory base tune compared to the 19.5 starter doesn't target what is on the boost tables. The factory tune I am assuming still has throttle pull back enabled to hit a certain amount of torque and the starter 19.5 takes that away. As I even with the factory base calibration and boost ramp up control turned off was never able to hit 19.5 PSI. So with the 19.5 base tune you are running more power and a couple more PSI over factory due to the fact this is turned off in the backend by these starter maps. Ktuner and others can chime in if this is the case or not.
You can alternatively copy the BBG tables and run them on any manual or CVT 10th gen
- Sport mode is running stock PSI until after 4000 RPM the values for boost found in the base tune take over with a smooth curve. (this should yield a more linear N/A engine feel)
- Stock 19.5 KTUNER base map boost
KTuner said: ↑
Yes. Honda deliberately left knock control to handle intake air temperature changes, rather than pulling a standard amount of timing like they've done on previous platforms. You can actually set this up, as I have, or if you're working with Vit or other tuners they've likely already done it for you.
With a tune file open find Ignition Corrections in the list on the left. Hit the plus to expand and find IAT Ignition. Here's how I have mine set for both load settings, and we've seen some extreme temperatures this year here in Arizona, so I'm taking full advantage. My IATs have been around 160 on the Si lately in the afternoon.
IAT(F) 95 122 167 194 212
Corr 0 1 1.5 2 3
My knock control stays fairly steady between .48 and .56 and I beat the car up pretty badly on a regular basis... for testing purposes, of course.
Also, Hello.
7. Early Spool
9. 800 RPM idle
- 01/29/2018 - Made changes to BBG 1st-6th gear after driving feedback
- 02/09/2018 - same psi in normal and sport, slight PSI change at 3500RPM, +early spool +15.1afr at >176c low load. 800rpm idle
