Si Coupe Backup Light HELP!
rwnl2012
HDMI Butt
Richard
Los Angeles, CA
2017 WOP Si Coupe, 2014 Kawasaki Ninja 650
So I used the Phillip's and Sylvania guide and they both said the reverse light for a civic was a 921 bulb. I have a Si Coupe and the bulb I ended up pulling out looks nothing like the 921 base. Does anyone know what the actual bulb is for this car? I'm not sure if its the Si that makes it different or if it's because it's a coupe! The OEM bulb has one of those little pins at the base that you have to turn to unlock the bulb.
Rob_13
Los Angeles 626
2016 Civic EX-L Coupe
h6w, dunno why the coupe gets to be the special one to get all different tailight bulbs.
brake light: 1156
reverse light: h6w
turn signals: 1156PY
bugboy32337
Tallahassee
2019 Civic Si Coupe (MSM)
I'm not sure if you have solved this question (you probably have, since it appears that it was posted quite some time ago ... but I'm looking to do some bulb upgrades, and was running into the same problem you describe) but the information that I have found indicates a Bax9s bulb.
