nullptr128
Hello!
As I am just buying X 1.5 CVT (Sport Plus version), I'd like to ask for a several questions - some of them are practical, while other are just pure curiosity. Its quite hard to find any technical informations about the car, so excuse me if questions like that were already asked on this forum - I dig some pages before I've posted
1. How does engine not stall when car is not moving, in this particular CVT? Does it feature "autmatic friction clutch" like in DCT transmissions, that disengages when car is coming to full stop and gently reengages when brake pedal is lifted? Or there is a hydrokinetic clutch (torque converter) that allows engine to spin even when wheels are stationary? Or perhaps there is another way in CVTs to overcome this problem (however I cant imagine belt slipping etc.)?
2. Related to question number 1 - is "inching" bad in this car? By inching I mean lifting brake slightly or completely for car to move forward. Does this produce increased wear or may damage transmission or its components or its completely safe to do so? Because in DCT transmissions this is considered bad habid as those transmissions rely on cluth slipping in order to "emulate" inching behaviour.
3. I havent driven automatic car for many, many years so I am not sure if this my fault or just car behaves this way. On test drive, sometimes I felt like I had an argument with transmission - my engine RPMs were rising as I pushed the pedal, which made me lift because I felt its now accelerating too quick and this resulted in sudden drop of RPMs - I couldnt find any sweet spot. Is that car specific or I am just not used to automatic transmissions and I'll learn how to control it? Now I am driving Civic VIII with manual transmission so pushing pedal results in straightforward car response, on test drive with CVT and turbo lag I felt like car cannot figure what I want it to do
4. How to properly deal with reverse gear? Should I avoid switching to reverse until car comes to complete stop or its not an issue in CVT transmission? Last AT I remember I had in Mercedes W124 and I know that it was serious mistake to launch the car before gear engaged (however this oldie was always giving feedback that its ready because it tried to move the car on brakes). And if I should come to complete stop before engaging opposite direction gear, how long should I wait until its engaged? Its like half second, one second or two seconds?
5. On every 0-100 move from Civic 1.5 (like this ) I see that there is some weird behavior of engine RPM between 4.5 - 5.5 k. It looks like its "gain" is slowing down for a brief moment. I am if the first gear of CVT is handled differently or its getting disconnected from torque converter or its just HUD issue? Edit: I think there is certailnly something changing with ratio as doing 0-70 km/h on first gear seems a lot.
6. I know this CVT features "fake shifts" but I would want to ask if they are present there all the time? Because when I was calmly test driving I didnt noticed fake shifting, it was more direct response to accelerator pedal. Does it behave like standard CVT unless I am flooring it or I was too excited to notice shift points?
7. What does ECO mode in reality do? It does something with engine map, gearing ratios or it does limit amount of fuel burned or it reduces resolution of throttle pedal or what? I've watched/read several sources but none of them provided reliable answer.
Thanks you!
Cant wait when car finally arrives
Thanks you!
