it's the catless downpipe creating the rasp.Sounds like a rice car... there’s just isn’t going to be a really good sounding exhaust for this car because of the engine
Thanks for providing feedback on your install and sound impressions. Making me think pairing this with my RV6 High flow cat and front pipe will be exactly what I am looking for.Just installed the exhaust today mated to a stock downpipe + stock front pipe. Only drove the car for about 5 miles but the overall sound is a 10/10.
However, ran into an issues which disappointed me after spending so much money on an exhaust. The flange on the SEQ exhaust is thick and the stock front pipe studs was too short for me to get any threads on the stud. Couldn't even get the nut to bite.
I am not sure if the one i got happened to have a thick flange because noone else seems to have that problem. It probably is not an issue if you had an aftermarket front pipe because it would be a bolt/nut instead of a stud.
I had it over at a friends shop and had everything already off so I opted to just hammer out the studs on the oem front pipe and went to Lowes to get a longer bolt and reused the oem nut. I already contacted Joe but I couldn't wait for his answer or a replacement part so i went that route. It was a major pain because the space is so limited there. Now that I think about it, probably would've been easier if i removed the front pipe and bolted it up off the car instead of trying to do it in that tight space.
Also I highly suggest you install the first and the second pipe connected before bolting it up to the front pipe. The hanger on the second pipe will be INSANELY hard to get on if you try to install it together. After all that work I had to do on the pipe that bolts to the front pipe, i didn't want to remove it again so I had to figure out and found a way to maneuver the hanger on ... but it took a really long time.
Other than that, the install was a breeze. If it wasn't for that stud issue, the install itself would've been a piece of cake. Slightly disappointed because I assumed everything would be trouble free after spending so much. Mine might have been a special case since I haven't read anyone else with that same problem.
Routing the vacuum line was a piece of cake. I removed the heatshield/plastics underneath the car and followed the brake line from the front to the back of the car.
Onto the sound.
When I initially started up the car to check for exhaust leaks, i was in awe. The car sounds like a stock exhaust (maybe even quieter) when you start it up. It was SUPER quiet. It was so quiet to the point where I had to second guess myself on whether this was the right choice.
Driving normally to warm up the car, the cabin has ZERO drone. Even less than a stock exhaust. it was so quiet you wouldn't even know you had an aftermarket exhaust on the car. It's so quiet that I may get a PRL front pipe to increase the note just a tad. Once the car warmed up and the I let the valves open ... there it was. The exhaust note came alive and sounded very clean and throaty. Still not overly loud.
This was the exhaust that I was looking for. ZERO regrets even with the issues I had. (which might just be a special case on the part I received.)
Sorry I have no other pictures of the install. I was semi frustrated trying to finish everything up after the front pipe stud issue i dealt with.
Edit: I do want to add that it was not a big deal cause it’s easily fixed by punching out the stud. I just wish I knew about it before we started so I don’t waste time having to go get some bolts ..
You totally won't be disappointed. This exhaust is literally what I was looking for. Not sure how much of it will increase with the front pipe but I may get that also. Probably won't introduce much rasp because I still have the cat there.Thanks for providing feedback on your install and sound impressions. Making me think pairing this with my RV6 High flow cat and front pipe will be exactly what I am looking for.
For those that are curious here are a couple test fit photos I took with the RV6 frontpipe and the hardware that was provided with it.
ordered it on sunday night 1/13, so basically 1/14 cause sunday is closed hours, and was shipped on wed and received it the following monday 1/21 here in cali. Joe is very responsive to email so you can always email. Depending on your preference, this is the exhaust to get imo. The welds are clean, titanium pipes is super light, exhaust note is great, muffler isn't too obnoxious from behind unless your paying attention to it. The muffler position is kind of a pain with how the hangers are bolted onto the muffler though. I guess you can think of it as a good thing too because it has adjustments to make it fit perfectly.@boosted180sx how long did you wait for your exhaust from the time you placed an order?
Very tempted to get this exhaust...
So nice, looks like stock from afar.
I had the same experience during install. It was the first time I installed exhaust myself. It thought it was a normal thing. After a week of driving, the position of the pipe moved a bit and started to rub against the heat shield.Just installed the exhaust today mated to a stock downpipe + stock front pipe. Only drove the car for about 5 miles but the overall sound is a 10/10.
Onto the sound.
Right now is probably the cheapest it will be for a long while. You missed out on the holiday sale when it was a couple hundred cheaper (10% off the $2799). I jumped on it at that point.I hope SQM will offer a group buy/sale for peasants like me to obtain their quality exhaust lol. Seems like more and more ppl prefer this over Boost Logic's.
do it! I drove it around again today for a few miles and it's great. No regrets from me.So nice, looks like stock from afar.
I think I’m going to buy.
I mean, right now he already has it at 2799 compared to original 3299. I asked him how long that price is good for and he just said until he sells a certain number so idk how long it's going to be good for.I hope SQM will offer a group buy/sale for peasants like me to obtain their quality exhaust lol. Seems like more and more ppl prefer this over Boost Logic's.
