boosted180sx
- Mar 27, 2017
- 25
- 5,038
- 5,088
- torrance, ca
- 2017 CTR, 2016 ILX
i didn't feel like going on in more detail with the conversation so i didn't say it lol.Nah, I'm just not at your becking call. Also, if you don't mind, clarify what type of engineer you are? The fact you didn't clarify makes me think you are a system engineer.
Boosted180sx did a good job of explaining it. Although, he kind of glanced over how your tires maximum grip is often the limiting factor in how quickly you can stop.
but basically,
tire is the most important part of the braking system. If you are triggering abs or skidding on the brake set up you are currently on, a better pad material is not going to decrease your braking distance. Hell, it may be possible that it would increase your braking distance because you can over outwork the grip of the tires more quickly and either trigger abs or skid earlier.
Once you have the tire part figured out, your next step would be to get brake pads. That would decrease braking distance due to creating more friction.
the next problem you will run into after that is, more friction = more heat. That's where the bigger brakes (rotors, pads, calipers) comes into play. Increasing the surface area of the brakes to disperse the heat over a bigger area and to dissipate heat faster.
alot of people think the bbk decreases braking distance because it utilizes bigger pads and that's not necessary the case. All a big brake kit does is lower the temperature that your brakes would operate at. A bigger brake pad will spread out the clamping force over a bigger area giving you a much better pedal feel but the friction between the rotor and the pad does not get increased. Thus not giving you a decreased braking distance.
