Safe Civic si whp/torque numbers
  1. GlahdoSI
    GlahdoSI Member
    Jul 5, 2019
    2019 Civic Si Coupe
    Hello fellow Civic X owners I was searching around the forums about safe horsepower/torque you can get out of these 10th gens. Would 300+hp/torque be something to crazy for a daily? Reading up on all these posts about blown motors is making me nervous
  2. saiko21
    saiko21 Senior Member
    Feb 16, 2019
    340
    145
    Occupation:
    Trust me I am an Engineer!
    Sacramento
    Sai
    2019 Civic Si Sedan, 2005 Toyota Corolla (Sold)
    Mostly you end up blowing the engine in long-term. Your clutch will definitely burn before that
  3. Bluecoupe777
    Bluecoupe777 Member
    Aug 3, 2019
    98275
    Eric
    2018 Civic Si Coupe
    I'm no expert on the matter, but even if you flash the car for another 30-40 more hp you are taking a risk to some degree. 300 hp/torque is going to require more of a budget, and that's an awful lot of power in my opinion to be pushing on these engines long term.
  4. Micah
    Micah Senior Member
    Oct 19, 2017
    2,102
    1,355
    Toms River, NJ
    Stock is safe. Anything higher is a risk. Modify and drive accordingly. Most of us feel TSP Stg1 is the safe limit.
    NoelPR, Prometheon and Bluecoupe777 thanked this.
  5. randomisjustfine
    randomisjustfine Senior Member
    May 14, 2018
    68
    75
    Harrisburg, PA
    Tadas
    2017 Civic SI
    Every time I come across this type of post and comments below I start wondering how you guys drive these cars, and where do you live.
    I consider myself an aggressive driver, and at the end of the day I find myself going above 20 psi(stock) maybe once a week for like 10 seconds. There is absolutely no reason to go above 6k rpm as well, since on every tune there is a drop off in both power and torque or it’s a flat line in that range. Usually you are somewhere in 4-6k range and bellow stock psi. Running in some kind of twisties, or creating your own ones while dealing with slower traffic.
    Now think how these cars are made. First of all they are made to comply with regulations. Emissions and mpg is what determines what hp/q numbers you see in 2019. It is absolutely not true, to think that 205 hp is the end of the line for reliability and performance. All the metals in your engine are probably stressed only at like 60-70% when you are flooring it around 6500 rpm and 20 psi. And it’s probably good for 220-230 hp if emissions are taken out of the context. That’s why you have same cars with same engines having different numbers in Japan or Europe let’s say. And no one makes a car that is capped at 99% stress levels.
    If you are going to drive your car at the redline with 6 more psi for thousands of miles then yeah... you are taking life from this engine. Otherwise, what makes you think that tuned car is all of a sudden is less reliable and only gonna live for 50k miles instead of 100k if you are driving even below stock limits and even more so below components capabilities for 98% of a time?
    Keep it lubed and it’ll get you to 200k miles.
  6. caspar21
    caspar21 2018 Civic Si
    Jun 7, 2018
    567
    387
    south central ontario
    2018 Civic Si
    80k on tsp1 with cm300 and prl dropin with intake pipe. i think it is about 270tq and 250hp according to other peoples dynos.
    recently sent logs to tsp and they said it is running perfectly and no tune adjustments are needed.
    i am flashing the dash 1-2 times daily and do track days as well as autocross.
    i consider this safe as i get zero blowby and everything is very healthy.
    more than this: i have no experience with.
    i know i have said all this in other posts, but this is a repeat question so i might as well repeat the answer:thumbsup:
    10GenPearlSi, Civic17siYAY, xbbnx and 3 others thanked this.
  7. Bluecoupe777
    Bluecoupe777 Member
    Aug 3, 2019
    98275
    Eric
    2018 Civic Si Coupe
    I think as I'm getting older I'm driving less in a spirited fashion, but as my last 3 cars made more power in Stock form I'll admit I won't rule out a ktuner or Hondata stage 1 tune when my warranty expires. But I'm thinking from what I heard earlier I may fry the clutch if too aggressive on the throttle.
  8. MoaRPowah
    MoaRPowah Senior Member
    May 30, 2019
    98
    99
    Norcal
    Mark
    2017 Civic Si Sedan
    I believe that the general concensus is that TSP stage 1 is still considered safe power levels. Don't drive like a maniac and keep maintenance up to date and the engine will be fine.
    I'm on TSP stage 1 for 8k miles now daily driven with a 60 mile round trip and I run on Map 2. Runs excellent with an average of 36 MPG still. This includes the occasional burst on on ramps here and there.
    If you have 300 hp and Tq, remember, it's not like you are going to be stressing the engine at 300 HP and Tq on every single shift every minute of everyday.
  9. OP
    GlahdoSI
    GlahdoSI Member
    Jul 5, 2019
    2019 Civic Si Coupe
    Personally I want to go Hondata, downpipe, frontpipe, Prl cobra cai, clutch and a nice custom tune I also drive this car 75miles to work so most of my driving is on the freeway
  10. EngineerEddy
    EngineerEddy Member
    Jun 30, 2019
    Bay Area
    2019 Civic Si Sedan
    Just curious since you've run 80k miles on TSP1:
    1. How often do you run map 3?
    2. Are you still running the stock clutch?
    caspar21 thanked this.
  11. caspar21
    Jun 7, 2018
    567
    387
    2018 Civic Si
    30% map3. 70% map2
    clutchmasters cm300 installed.
    EngineerEddy thanked this.
  12. Micah
    Micah Senior Member
    Oct 19, 2017
    2,102
    1,355
    Toms River, NJ
    nearly 100% map 3, over 15k miles, stock clutch is fine - don't abuse it and it lasts
    TornadoredGen3 and Civic17siYAY thanked this.
  13. SHAYN3R
    SHAYN3R Senior Member
    Dec 4, 2018
    103
    76
    Occupation:
    Millwright
    CAMBRIDGE
    SHAYNE
    2018 Civic Si
    I stay on map 1 for a lot of the time.
    ...It's so hard to stay away from map 3 though, all them torques are addicting.
