Sad day, AC condenser broken by stone
Tags:
  1. OP
    FedCO
    FedCO Senior Member
    Apr 30, 2016
    85
    Occupation:
    Law Man
    16 Honda Civic LX 2.0l 6spd
    Total bs isn't it. Sadly us Canadians have no recourse it seems. Honda left me high and dry. Also Honda paint still sucks as well. Almost at 60k now and no real issues. Rear brakes were toast though. So had to replace rears Fronts were mint..
  2. Sitio23
    Sitio23 Senior Member
    Aug 14, 2017
    137
    16 EX Civic
    So I just got my quote to replace the AC in my car. Picture attached. Does anyone recommend another service area besides the dealer in Los Angeles, CA? Seems a bit steep if you ask me.
  3. SCOPESYS
    SCOPESYS Senior Member
    Aug 27, 2018
    2,375
    1,286
    MD
    Geoff
    $150 !! there must be more below that we cannot see on that Invoice.
    You can't get much done at a Dealership for just $150 -- is that just the cost of the Diagnosis..
    If so, what is the estimated cost of the repair ??
  4. Sitio23
    Aug 14, 2017
    137
    16 EX Civic
    It is to the left. Estimated price is $1,950.57! However, I just took it to a friends shop and he was able to make it "work". Not the best solution but the cheapest for right now.
  5. SCOPESYS
    Aug 27, 2018
    2,375
    1,286
    MD
    Geoff
    OMG $1,950.57 That would be funny if it wern't so sad !!
    Good to hear it's working again... ( quick top up ? )
    You can get a lot of Top-Ups for $1950 !!
  6. GoodBytes
    GoodBytes Senior Member
    Mar 24, 2018
    110
    Montreal
    Honda Civic 2016 EX
    What I have done, is bought aluminium black colored (so you don't see it) insect screen for windows, which you can easily find at your local hardware store, and some black metal tie wraps/twigs from the dollar store.
    Cut a rectangular peace, slide it under the opening of the car large vent holes (and now for the tricky part, but obviously much easier if you remove the bumper of bottom access panel.. I didn't do this as I don't have the tools), unroll it inside without touching the condenser, used the tie wrap, bent a bit, then go through the hole of the window screen, and attempt at passing through another opening and attach it on the bumper plastic separators in the vent opening. Once you are happy with the results, make sure the tie wrap are secured, and cut the excess. Note sure nothing is loose (else it will make noise as you drive)
    If you didn't remove the bumper, or lift the car to access the panel, and you want to do a good job, you are looking at about 3h of work.
    If you do take your time, and you have serious patience in trying multiple times to attach the tie wraps, especially if you want them close to the bumper vent separators, and you want them to put at the top and bottom of each vent, for a secure fit and be the least visible as possible, you'll end up with something that is not visible at all unless looking up close and down.
    You can do a better job, and faster, if you know how (and have the tools) to remove the bumper. I didn't. If you don't mind paying, maybe ask a mechanic as another option to have that installed.
