RV6 Performance FK8 Civic Type-R Frontpipe
RV6
IL
rv6-p.com
2020 CTR, 2023 Civic Si
After several seasons of racing RV6 is finally ready to release its frontpipe for the FK8. This frontpipe was designed using Solidworks 3D modeling and our Creaform 3D laser scanner system for precise measurements and fitment. This frontpipe replaces the highly restrictive 2.37" OD front pipe with free flowing 3.0" OD tubing. This front pipe will bolt directly to the factory and any aftermarket exhaust system. The entire assembly made of high quality 304 stainless steel and is TIG welded by our master welders in the USA.
Preorder is over.
PURCHASE HERE
Availability Mid December 2018
Specifications:
- Full 304 Stainless construction
- 3" OD Tubing throughout
- Double lined interlock flexpipe
- Fully TIG welded
- Argon back gassed for pure welds
Includes:
- All hardware needed for install
- Graphite gaskets with sealing ring to prevent blowout
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe RV6-CTR-FP21
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe RV6-CTR-FP20
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe RV6-CTR-FP23
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe RV6-CTR-FP8
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe RV6-CTR-FP10
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe RV6-CTR-FPR
Honda Civic 10th gen RV6 Performance FK8 Civic Type-R Frontpipe rv6-ctr-frontpipe
Tim818
King Of The ‘Ring
Texas
2006 Civic EX, 2018 CTR
Just placed an order, gonna need this just in case...
RV6
RV6
IL
rv6-p.com
Nice! there's ceramic coating available? Is that really needed?
Yes, ceramic coating is available. There is a drop down menu to select it before adding it to your cart. All of parts are made of stainless steel so the coating isn't required. However the ceramic coating does a great job keeping the heat inside the tubing. This translates to cooler temps and higher exhaust velocities.
jmartin
Rouleur
Nj
2018 Ctr 2015 Challenger srt 2016 Yamaha R1m 2002 Gmc Lifted Duramax
Coated Fp will go nice with Ti exhaust on order. Order placed thanks Rv6
CincyTypeR
2017 Type R #0426. 2014 Accord Coupe V6
Order submitted! :D
mdub83
Tyler, TX
2018 CTR in White
will install instructions be included?
CincyTypeR
Someone probably has a frontpipe install directions somewhere already. This should be a pretty straightforward install though.
Would guess a simply instructions are
-Remove the under tray
-Remove 6 bolts
-finesse the frontpipe out
-reverse steps above to install
baldheadracing
Craig
Canada's capital
FK8
-Remove 6 bolts
Add:
- for some installs, p*ss around with the exhaust hanger and finally give up and get an exhaust hanger tool (try WD-40 and pliers first); and
- add some kind of insulation like header wrap or DEI's pipe shields (or if you're anal like me, both) to keep exhaust heat away from the oil pan, dogbone, steering rack, etc.
CincyTypeR
Add:
I did black ceramic option so won't do any wrap at this time.
youCTR
North Bay, CA
1292 CW Civic Type R
Why is the silver ceramic coating $10 more? Is there an inherent difference between the black option? Just curious...
baldheadracing
Craig
Canada's capital
FK8
Cool.
The silver is polished after coating; the black is left matte. One could argue that the silver polish should work better, but I suspect that the difference is negligible.
#04338
Kenny
Richmond,TX
17 Civic Type R
Placed an order for FP. Cant wait to have it mate to my RV6 catted DP. :drive:
