Rooted Stock headunit- What's your setup (apps)
  1. SCOPESYS
    SCOPESYS Senior Member
    Aug 27, 2018
    2,444
    1,353
    MD
    Geoff
    GOOD Question ...
    GOOGLE STORE .. but you may not want to download them direct to the Honda Hacked HU .. having that Google Software on the HU, is not the best Idea.
    So 2 options.
    (1) Download the APP to your phone .. export it to a flash drive, and then uninstall it from the phone. Install to the Honda HU from the Flash Drive
    (2) There is a website that will go fetch Apps from the Google store, and then let you download the App direct from them. (Cannot remember the site -- sorry -- but Google should be able to find it). save to a Flash drive, and then Install from that Flash drive.
    I have a old test China head Unit that I use to download and test APPS that I am thinking of putting onto the Honda Unit. I can test them first before committing to installing them on the ROOTED Honda Unit... you always want to be careful what you install; on the Rooted Honda Unit .. potentially a "Bad" app could do a lot of damage to a Rooted Android unit !!
    The other advantage of downloading and EXPORTING them (say to a Flash Drive) is that you can keep a collections of APPs that you use, and that work, on the flash drive for future use.
    Then if you ever get an update version, and find that newer version has issue that the earlier version did not ( not Uncommon, as the Honda Unit is an old OS, and some new apps will not run correctly on older OS), you can always re-install the older "know to work" Version.
    kung fu kenny thanked this.
  2. warrior64nd
    warrior64nd New Member
    Jan 26, 2019
    Columbus, Ohio
    Nick
    2018 Civic Si, 2004 G35 6MT
    Sorry for the delayed response, you can set them in the gauge's menu. I chose to hide the scale numbers for appearance purposes. Once you change the clock position, like i did, of the boost gauge it automatically starts at 0. My max is 15 because i like to see the dial fill up. No mater what the number will display regardless of the max and min. In the settings there is setting that says number of display pages you can select 1, 3, and like 5 i think.
  3. Syco54645
    Syco54645 Senior Member
    Nov 8, 2018
    78
    PA
    19 Civic Ex Hatch, Nissan Altima
    Does honda hack allow the phone button to go to car play/android auto when it is enabled? I think this is a big miss in the original design. Hoping honda hack can fix this...
  4. Justintime37
    Justintime37 Member
    Apr 22, 2019
    San Diego
    2019 Honda Civic Ex Hatchback
    What controller are you using?
  5. Dimitron84
    Dimitron84 Senior Member
    Mar 25, 2018
    399
    174
    Youngstown, OH
    Patrick
    2018 Civic SI
    LMAO "shits hard to do with one hand" because your filming that's hilarious! What's the emulator called that you got to run on it? Also ya what's the controller that you got to work?
  6. imaya
    imaya New Member
    Jun 20, 2019
    Civic 2019 LX
    One last point to add to the setup. By the way I installed Waze & Spotify and everything works perfectly smooth. As Waze require internet, I added Tasker on my Cell Phone to turn on Tethering as soon as it detects my car bluetooth. Results: as soon as I start the car it is connected to internet, no manual intervention required.
    Android also have the auto off tethering when not in use so no need to turn it off.
    GeoUSA thanked this.
  7. Dimitron84
    Mar 25, 2018
    399
    174
    Youngstown, OH
    Patrick
    2018 Civic SI
    Honda hack has now added the Google store as an APK to it's latest update.
    mrturtle8088 thanked this.
  8. BigDog
    BigDog Senior Member
    Nov 29, 2016
    111
    72
    Minnesota
    '18 Si Coupe, '02 Mustang, '01 Silverado
    Does anyone have a nice simple weather radar app that they use? The one I use on my phone (Raindar) won't install.
  9. Starks
    Starks Member
    Jul 11, 2019
    New York
    2019 CR-V EX
    I've had no luck with radar apps. They're all too slow.
    My app setup matches most here. Yalp Store is an absolute must. Removes all the guesswork with API compatibility or filtering out apps that require Play Services (some do but don't really enforce it to the point of being unusable).
    And yes, it runs Doom.
  10. HoldTheRice
    HoldTheRice Member
    Jul 11, 2019
    57
    Western MA
    David
    2019 PWP Civic Si Sedan
    This is the most boss shit ever, I have one of those buffalo controllers too. Now I gotta do it :D
    NoKz thanked this.
  11. NoKz
    NoKz Speed Limit Tester
    Jul 23, 2018
    789
    1,022
             '18 Si Coupe     '19 Si Sedan   '00 Civic Si    '00 LSV Integra
    Worth it man. I've killed so much time waiting in my car with it. :headbang:
    HoldTheRice thanked this.
  12. lturner
    lturner Senior Member
    Jan 7, 2018
    74
    37
    Occupation:
    Tower monkey
    Nebraska/South Carolina
    Lucas
    Ctr, couple of itr’s
    Do you have to use a certain USB controller? I have a cheaper USB gamepad/controller and it doesn't work.
  13. jspencer89
    jspencer89 Member
    Feb 2, 2019
    New Jersey
    Jiles
    2017 Honda Civic Sport Touring Hatchback
    It took me a long time to get this work. I finally got Android auto to wireless connect to these head units.
    You need to have Android Phone that can do mobile hotspot. I'm using a Pixel 2 XL not rooted.
    Please let me know if anybody else has done this. I have used an app called Headunit Reloaded available on the play store.The app has a free trial but normally it is available for $4.99.
    I suggest only installing the trial version to test this works for you first.
    To get this to work I used Honda hack the latest version.
    Enable hotspot for all of these steps.
    1. Install Honda hack
    2. Install account manager and Google play services. From Honda hack. You will have to restart the radio and login to get it to work.
    3. I installed a Google play store APK.The one I had from a long time ago I'm going to try to get it off of the unit and upload it here if anyone is interested. I think I must have installed it via the USB.
    4. Install Headunit reloaded from the Playstore on your phone.
    5. Open the Android Auto app on your phone and go to the menu and about and tap the version number until developer options are enabled.
    6. After developer options are enabled you're going to want tap the three dots on the top right of the screen and turn on head unit server.
    You will be prompted on your phone to setup android auto. ( I found deleting the Civic made a faster connection/ easier connection if you get trouble getting the screen to pop up)
    Headunit Server and hotspot need to be on upon entering the car for the transition to happen. You need to select the wifi option in Headunit Reloaded for the connect to establish. It will give you a black screen give it a couple seconds.
    Here's where this gets tricky I got the Playstore to install the trial but because the full version cost money the headunit said I could install it but it still tried to charge me after I purchased it when I sign in to purchase it again in errors out and tells me I own it already.
    I do not condone piracy but I used an APK backup app (Titanium Backup) to backup my paid app and then to send the app to my Google drive. I'm looking for a better workaround. I for some reason also started getting Google play service errors with opening drive to but I was able to quickly tap the APK before the app crashed and I was able to download it.
    Something tells me this only worked for me because the play services is telling the app it's been paid for. Otherwise I feel like some failsafe would have been put in place.
    If you guys need more info I will update this further. I can do a better write up with a video when I have more time. The developer of Headunit reloaded is still active, I want to see if he can make some adjustments.
    Things that I have found while using for a week.
    It can freeze sometimes. But when it works it's amazing.
    YOU NOW HAVE FULL BLUETOOTH AUDIO CONTROL WHILE USING ANDROID AUTO.
    Just hit Home, audio , and sound settings.
    Hope this helps someone out there.
    Anyone else have some input please let me know.
  14. Starks
    Starks Member
    Jul 11, 2019
    New York
    2019 CR-V EX
    Using Headunit Reloaded for wireless is dumb. Yes, it works, but AAGateway is actually designed for this specifically and preserves the built-in AA functionality. Same developer.
    HUR will reduce your ability to mix audio sources (i.e. radio and directions) and take away the nice AA phone call screen. Steering wheel controls may not work properly either.
    Plus, you installed HUR using the Play Store rather than through the more ideal XDA Labs. The app is rarely updated on the Play Store to begin with. Play Store and Play Services wreck your head unit and slow it down to a DANGEROUS level especially when backing up. Uninstall them and any updates both apps have ASAP (uninstall from both the Honda Hack uninstall menu and the dedicated Play Services uninstaller). You will not get proper Play Services and paid apps working like you want, so stop trying. Even if you got your license working, it would break again after uninstalling Play Services. Use XDA Labs and Yalp Store for apps. HUR paid licenses work when installed through XDA Labs. You bought the wrong license and they're not transferable. Maybe the dev will honor your purchase. He's usually very understanding.
  15. Naruske
    Naruske Senior Member
    Mar 10, 2017
    307
    182
    NJ
    2019 CTR
    The only thing i have on my head unit is the honda hack and it's slow as hell. How do you guys have no lag and such. I just did it yesterday so i dont know if needs some time to get used to this but it's really killing it for me :/
    Also how do you clear the messages when you scroll from the top? I got a tire pressure signal yesterday which went away already but on my headunit it still shows the message? I tried to see if there is a clear messages but maybe i overlooked it?
