Rock/Stone in the Brakes (Video)
  1. ale99llamas
    ale99llamas Member
    Jan 23, 2020
    San Jose, CA
    Alex
    2019 FK8 Rallye Red
    Anyone else getting the same issue? Happens only when going in reverse and I am not even pressing the brakes.
    Is it a stone/rock in the brake ?
    Any luck with an easy fix without removing the wheel ?
  2. TheSnakeJake
    TheSnakeJake Senior Member
    Oct 10, 2018
    105
    57
    Cincinnati
    Jake
    CTR
    yes, it has happened to me twice. definitely a rock. most likely will need to remove the wheel to reach in there.
    ale99llamas thanked this.
  3. Nitroturtle
    Nitroturtle Senior Member
    Feb 4, 2019
    177
    130
    WV
    2019 PMM CTR, 2006 S2000, 2011 CR-V EX, 2007 Element LX AWD
    Two things I've done, on different occasions, that did the trick. Quick forward and reverse and jamming on the brakes cleared it once. The other time I used a long prybar to gently tap on the heatshield and push it away from the rotor and the stone dropped out. Obviously it'll depend on how badly it's wedged in there, but you can try these to see if it does the trick.
  4. Hayabusa160
    Hayabusa160 The Master
    Jun 19, 2018
    268
    94
    Occupation:
    Master of all things Magnetic
    New jersey
    Matthew
    Civic type r
    the big ones you have to remove the wheel to get it they basically sit on top of the caliper mounting ear resting and they bounce around when moving it sucks going to 18s greatly reduced it but you will still get them lol i got one right now thats making all sorts of noises when going in reverse i got to pull the wheel off this weekend and get it
  5. OP
    ale99llamas
    ale99llamas Member
    Jan 23, 2020
    San Jose, CA
    Alex
    2019 FK8 Rallye Red
    Well it was this damn pebble/stone. And it sure was hard to get as it was close to the brake caliper and laying on a flat surface.
    Had to remove the wheel. Push the dust shield back a bit to reach it and push it out with needle nose pliers.
    It’s nice to finally pull out of a parking lot without sounding like an aluminum can tearing up your brake and suspension systems.
    blitz and Nitroturtle thanked this.
  6. blitz
    blitz Member
    Jan 26, 2020
    45
    Virginia
    2019 Civic Type R
    That has happened to me as well, and in the same place (resting on flat portion the caliper). I used a probe pick to dislodge it first, which caused it to bounce/fall on the caliper, and then I used an extended zip-tie to push it out. These tires are so sticky and pick-up pea gravel so easily.
  7. fatherpain
    fatherpain Senior Member
    Dec 22, 2018
    676
    540
    Tom
    2018 CTR - CW, 1995 Honda Accord
    If you have a pressure washer, try spraying the rotor, caliper and pads really well. That might clear it. Sometimes it’s an accumulation of brake dust.
  8. Fk8Desu
    Fk8Desu Member
    Jul 11, 2019
    Northern Virginia
    Honda Civic Type R
    I've been to the dealership to get rocks removed but for them to get right back in on the way home. I've taken off my wheels and gotten so accustomed to removing the wheels and pads from the brembos that I can do it my sleep.
    It's just frustrating whenever I brake the squeels come back but only right before I give the final pressure to stop completely, not just when I press my brakes. I thought it could have attributed to my pads being glazed? I resurfaced my pads but still having the same issue. It sucks that the roads around me are paved, but the outer boarders are gravel, so people who veer off road (which is common in this area) bring back the gravel onto the roads, etc.
    It's just really embarrassing to stop at a light and announce to the whole world and their mother. I apologize for sounding like I'm bitching but I have no where else to do it. Dealership told me it's a common issue. Almost thinking about trading in the car...
  9. fatherpain
    Dec 22, 2018
    676
    540
    Tom
    Brake squeal is the absolute worst. So annoying and embarrassing for the car to make that god awful sound.
    I experienced it 5-6 times during the first several months of ownership. Same thing, I took it to then dealership to fix. Sometimes they found rocks, other times they said the brakes were just dirty.
    The issue got much better after picking up a high volume pressure washer and making sure to spray the brake pads really well at each wash.
    It appears to be completely resolved ever since I switched out the front rotors and pads for Girodiscs. Much less brake dust and they don’t have the deep grooves the OEMs have.
    Before throwing in the towel, would highly suggest trying the above cleaning method along with switching to another front rotor and pad combo. Doesn’t necessarily need to be Girodisc because they are abit pricey... but I can confirm from my experience they work good and no squeal since they have been installed and there is a lot of gravel, dirt and rocks at my work. Much less brake dust also.
    Fk8Desu thanked this.
  10. Fk8Desu
    Fk8Desu Member
    Jul 11, 2019
    Northern Virginia
    Honda Civic Type R
    I appreciate your suggestions and will definitely give it a try, at least the power washing portion. Just doesn't sit right with me that the issue is so common and yet Honda is not announcing a fix. I would rather not spend additional money to fix an issue that shouldn't even be present in the first place.
    Thanks again
    fatherpain thanked this.
  11. MutatedMango
    MutatedMango Senior Member
    Mar 24, 2019
    339
    131
    Occupation:
    Student
    Philadelphia
    '19 Civic Si coupe
    Had this on my Si when I first got it as well. Was really annoying and sounds just like you describe it lol
  12. blitz
    blitz Member
    Jan 26, 2020
    45
    Virginia
    2019 Civic Type R
    What brake pads did you pair with the Girodisc rotors? Did you also replace the rear rotors and pads?
  13. fatherpain
    Dec 22, 2018
    676
    540
    Tom
    Front Girodisc rotors are paired with Girodisc SS pads.
    Rears are still OEM with Girodisc Magic pads. Would have gone SS also but they weren’t available at the time. The SS pads are street pads.
    blitz thanked this.
