Current FK2R uses 5x120 19x8.5 +60 on 235/35/19.
I'm going to guess the FK8R will be very similar. Most likely 20x8.5 +60 on 245/30/20.
For winter, I'd go with 225/45/18 with 18x8 wheels.
Will +45 offset work? That is like the highest I'm seeing? Dumb question I know. I'm a wheel newb.Just spent a good part of the evening looking for 19" wheel options with a 120x5 bolt pattern and high offsets. They may not so easy to find.
OK, for those looking for a 19" (or maybe an 18" wheel option) I just took a quick look at the Enkei website and there may be some possibilities but the 5 bolt by 120mm pattern and high factory offset (if it's ET60 or +60) sure might limit the possibles.Honda has a long history with using Enkei MAT wheels for the factory original equipment wheels. -Very solid choice for a factory wheel.
Do we know stock rim width? I would imagine it's 20x9? If this is the case, I would hate to downsize width. Enkei's are a great wheel, I have a set of nt03+m's in 18x10.5, nice and light, reliable too. I hope they release something classic that fits the new bolt pattern.OK, for those looking for a 19" (or maybe an 18" wheel option) I just took a quick look at the Enkei website and there may be some possibilities but the 5 bolt by 120mm pattern and high factory offset (if it's ET60 or +60) sure might limit the possibles.
Depending on final wheel specs, brake clearance, and inner fender clearance here are some possibles Enkei have.
NOTE that brake clearance may become an issue for any of the 18" wheels listed. Just not sure yet until we get further specs and some of the wheel distributors have a better look at the car.
Possible Enkei wheels (?):
Name, Dia x Width, Offset
Raijin 19x8.5 +38 or 18x8.5 +38
RSM9 19x8.5 +42
TSP6 18x8.5 +35
TX5 18x8.5 +35
TY-5 19x8.5 +38 or 18x8.5 +38
GTC01 RR 18x8.5 +35
The following Enkei wheels only come 8.0-inch widths with a maximum recommended tire width of 235mm versus the wider new OEM tire at 245mm wide. However, not quite as much offset would be needed for a slightly narrower rim (1/2 of 0.5 inches):
TS6 18x8.0 +42
VR5 18x8.0 +42
YS5 18x8.0 +42
SS05 18x8.0 +40
