ThatDustyFox
I'm on the fence about either getting the Spec 3+ with the steel SMF and Eman's upgraded CMC or driving up to Eman to have a CTR retrofit done. The thing that bothers me about the car with a CTR retrofit that I've had a chance to drive was that the tach developed a sort of "lag" after the CTR clutch was installed. I'm not sure if it's unique to this particular car, or if it's a widespread issue, but when you rev the car the tach needle lags behind what RPM the car is actually at. You can test this by comparing at what point you hear your two step engage vs at what time the tach actually displays the correct RPM that your two step is set at. A KTuner v2 still reacts as quickly as it should, but for some reason the dash does not. The owner claims that Eman told him any lightweight flywheel will have this issue, but I brought it up to Eman and he seemed to have no clue about the issue or it being related to a flywheel if such an issue did exist. Does this happen with your Spec clutch as well? This is currently the deciding factor for me.
Any thoughts regarding the concern I expressed above? The lag is what's keeping me from buying a CTR clutch from Eman, but if it's not present with the Spec, I'm going to buy the Spec.ORIGINAL POST UPDATED! PLEASE CHECK IT OUT!
I updated the original post with my findings after adjusting the clutch pedal. Spot on advice that worked beautifully! Thank you!
Thanks for the vid, I had seen it before and you saved me the time of having to hunt around for it.
Thanks, I appreciate the feedback. I tried to make it somewhat informative and entertaining enough to get the point across. We need more clutch reviews on this forum. To be honest, I'll most likely putting a Clutch Masters in my wife's Si for comparison and review that as well.
