Retrofit Heated Mirrors
17CivicTypeR_Brian
York PA USA
I tapped my Suma mirror heating element into a wire from the rear defroster that I traced to the wiring loom near the drivers rear left foot. I have run my defroster several times over the past couple months and no issues whatsoever.
Honda Civic 10th gen Retrofit Heated Mirrors upload_2019-11-6_11-9-43
The Accord at least uses a pink wire for the 'hot' side.
Following the blue and Brown wires back to the first page it looks like it has a 10amp fuse. It's not entirely clear what happens inside the modules. It's also no guarantee that the Civic does the exact same thing. The Accord, for one thing, has memory mirror position which the Civic does not...
The passenger side mirror uses a different color for the 'hot' wire.
Chicago
17 civic hb sport
You have more pics and info about this?
fk-eight
Sacramento Area
2019 SGP CTR R-35355/ 2021 SGP Accord Touring
My 2019 only has 900 miles on it, so, I didn’t even know that it didn’t have defrost mirrors. For a high end car, this car is super basic. For $7,000 less, my Cruze hatchback has every option possible. Kind of missing all the tech in my Cruze.
martindtjr
Martin
San Diego
www.flickr.com
TYPE R 19, Sienna XLE15, Xa 06, Camry 92
I bought a heated set from Suma. they measure 14.8 ohms. each.
I'm going to try. I bought a set of Suma heated mirrors. They measure 14.8 ohms. IDK if they are using 12 vdc on a timer or an ac on a timer.
Chicago
17 civic hb sport
I bought a chinese reps similar to Sumas for $70. since my car dont come with heated features, I have to make my own wiring and bought a timer module with a switch. Ive installed the mirrors, havent got around to do the wires yet
martindtjr
Martin
San Diego
www.flickr.com
I found a timer on amazon. Only need a defogger once last year when it was rainy.
Volksparts
Dave
San Diego CA
19 CTR, 17 TRD Tacoma, 2017 Wrangler, 2020 Avalon
Sorry man I didn't take pics or do a writeup. I used to be a stereo and alarm installer so I have experience doing stuff like this. It took me some time to trace all the wires for this install. I ended up tapping the left turn signal for the mirror up near the left front footwell near the fuse block. And then I tapped both defrosters into a wire near the left foot rear seat wiring loom. I was also able to tap the right turn signal near the defroster wire in the same area.
It's been several months and all still work very well.
martindtjr
Martin
San Diego
www.flickr.com
I found it. C-128 location drivers footwell pin 1.
17CivicTypeR_Brian
York PA USA
Just confirming and saying it out loud - this is for the Defroster right?
Did you use an additional relay to power up the mirrors or just power right to them?
martindtjr
Martin
San Diego
www.flickr.com
I'll test it out, hold on.
This is the wire for the rear defroster. Tested it with Fluke 77 meter.
Hlee
Harry Lee
2018 Civic si
Hi, I have a 2018 Civic si and trying to do the same install witha a Suma mirror with defroster and signal. Not sure how to wire the electrical. You mentioned the location C-128 at driver"s footwell pin 1. Is this where to tap in the defroster and signal. Can please give me some insight?
Chicago
17 civic hb sport
I finished installing my side mirrors with heated and sequential turn signal.
For signals, I had no choice but to route directly to the side headlight signal wire.
For the heat function, I bought a timer module from amazon and used that.
It all works flawlessly.
Timer module is set at 10 mins and turns off automatically. I feel the heat on the mirror.
Honda Civic 10th gen Retrofit Heated Mirrors Screenshot_20200516-005829_Video Player
Hlee
Harry Lee
2018 Civic si
Can you share the link from Amazon on the timer module you purchased? Some people tapped the heater mirror wires to the rear defroster. Is that a bad idea or why you didn't go that route? Where did you get your mirror with heater and signal? Got a link for that as well?
Si_chRis
Connecticut
2000 Honda Civic Si, 2018 Honda Civic Type R
You can tap into the rear defroster as a power source, but it adds additional load with the side mirrors which can lead to blowing the fuse for whatever runs on that circuit.
Hlee
Harry Lee
2018 Civic si
You got a point there about the extra load. Wouldn't want the fuse keep blowing. Anyways what timer module did you purchase from Amazon and how did you hooked it up. Did the connect it to the fusebox under the driver's side. At what amp fuse?
