Retracting parking brake with scan tool?
  1. Gansan
    Gansan Senior Member
    Sep 13, 2017
    236
    206
    San Diego, CA
    Glen
    1999 NSX, 1998 Integra Type R, 2018 Civic Type R, 2003 Chevrolet Silverado 2500HD
    Hi guys,
    I know there have been threads on how to retract the parking brake and piston manually when changing out rear pads. However, I noticed that there are scanner tools that retract electronic parking brakes for other makes of cars. I expect there must be support for Honda parking brakes in one of them already or maybe it's coming soon. I'm willing to spend some money on this--does anyone know of a tool that supports the Honda parking brake retraction command?
  2. baldheadracing
    baldheadracing Senior Member
    Jan 4, 2017
    1,223
    1,308
    Canada's capital
    Craig
    FK8
    #2 baldheadracing, Aug 6, 2019
    Edited. Well, I got that wrong ... :bonk::(
  3. shadow
    shadow Senior Member
    Jan 19, 2017
    133
    72
    Earth
    11 STI, 15 CRV, 16 Civic RS Turbo, 18 FK8
    #3 shadow, Aug 7, 2019
    The rear brakes are operated by two systems:
    1. Electric parking brake - It is operated by a motor and system of gears that actuate the piston.
    2. Hydraulic system - Rears are like conventional brakes when the parking brakes are off. Hydraulic fluid actuates the piston.
    What I don't know which system is used by the brake hold feature.
    Here is a tool that may work.
    https://www.ebay.com/itm/For-HONDA-...2644?_trksid=p2349526.m4383.l4275.c1#viTabs_0
  4. Type R 761
    Type R 761 Member
    Mar 8, 2018
    45
    Montréal, Canada
    Marco
    FK8 Civic type R and VW sportswagen AWD
    Hello, Autel has some, you can buy from Amazon. 150 ish. Works great, no need to take apart brake motor end unscrew manually, makes the brake job faster. They will give you a free download. So Honda/Acura is covered. You can have more cars leaded for extra $ once purchased. It also reads/deletes codes. So very useful. Let me know if you need exact model ,# I'll check when back home
    Gansan thanked this.
  5. 02SilverSiHB
    02SilverSiHB Senior Member
    Jan 3, 2018
    2,196
    1,340
    Annapolis, MD
    2017 FK8
    Dang 150 for that...I just released my brake before working on the brakes...seemed simple to me...guess it depends on your situation/how you have to park your car?
  6. shadow
    Jan 19, 2017
    133
    72
    Earth
    That will work when installing pads with the same thickness.
    Will it work when changing thin worn pads to thick new ones?
  7. 02SilverSiHB
    Jan 3, 2018
    2,196
    1,340
    Annapolis, MD
    2017 FK8
    So after I took off the rear pads I just retracted it by hand...it was easy. Then I had enough room to slide the rears on.
    My brakes are fine work great. This was like 4k miles ago I guess
  8. shadow
    Jan 19, 2017
    133
    72
    Earth
    I'll try that when I replace the rear pads.
  9. 02SilverSiHB
    Jan 3, 2018
    2,196
    1,340
    Annapolis, MD
    2017 FK8
    yeah, it wasn't hard honestly. I'm sure you've done it before on previous civics maybe? This one obviously has that motor for electronic brake, but it wasn't hard at all...the initial turn clockwise was a bit tough, but once it start turning it'll be super easy (guess it could depend on mileage and brake use, I haven't put mine on the track at all)
  10. OP
    Gansan
    Sep 13, 2017
    236
    206
    San Diego, CA
    Glen
    #10 Gansan, Aug 9, 2019
    There are some people who have reported just releasing the brake and changing the pads out (with manual piston twist I assume) led to weird problems. I'm guessing by resetting it, you are having it retract fully and reset where the "open" position is. Otherwise, if you release it and put new pads in, then the open position is probably a lot closer to where closed would be with new pads. The position is probably designed to ratchet closer and closer to accommodate the pads wearing out over time, same as manual parking brakes.
  11. 02SilverSiHB
    Jan 3, 2018
    2,196
    1,340
    Annapolis, MD
    2017 FK8
    I haven't had the issue...doesn't make much sense to me...but we'll see...it's been quite a while and zero issues for me.
    After I finished the rears, I lowed the car down, got inside the car, turned it on and pumped the brakes to feel if all was good. I then put the ebrake on and tested that out, then disengage the ebrake and drove around...and no issues
  12. shadow
    Jan 19, 2017
    133
    72
    Earth
    On the old Civics, I turned the pistons clockwise to retract it.
    The 10th Gen Civic FSM say to first retract the EPB by electronic means, or removing the motor and turning the shaft clockwise. Afterwards, use a brake tool to push in the piston.
    FYI, when my car was new, I replaced the rear rotors with Girodiscs. While it was off, I tried turning the pistons like the old Civics. that was too difficult. I next tried to push is straight back in, but that was too hard too. I was afraid to break something and since the old pads were going back in, I didn't bother to remove the motor.
    I'm just wary if it is as simple as tuning the pistons, why does the FSM require retracting the EPB.
    360glitch thanked this.
  13. 02SilverSiHB
    Jan 3, 2018
    2,196
    1,340
    Annapolis, MD
    2017 FK8
    Interesting. I think getting the tool is probably a safe bet then. Either I got lucky or I'll have issues later down the road...we will see. My next brake work, I'll just have honda do it and have them inspect them to make sure all is good
  14. FK8 Twigs
    FK8 Twigs Senior Member
    Jun 19, 2017
    232
    130
    IL
    CTR #01007
    I've been having intermittent issues with my EPB since changing the rear pads and manually retracting the piston. My assumption was that it's confused by the new position of the piston when the brake is engaged. I've just been trying not to use it until I can go to the dealer, hoping they'll reset it for me with my next oil change.
  15. baldheadracing
    Jan 4, 2017
    1,223
    1,308
    Canada's capital
    Craig
    FK8
    Did you bleed the brakes? (and follow the parking brake reset procedure of 5x on-off and re-bleed? )
    If you didn't bleed, then that would be a different issue.
