tinyman392
- Marcus
- May 21, 2018
- 14
- 3,265
- 2,082
- Illinois
- '18 Civic Type R (RR)
Was this under hard acceleration or cruising? If youâre cruising then the exhaust pressure isnât strong enough to spool the turbo and itâll produce a vacuum. Even under a light load you might not produce any boost.Really knowledgeable tech. Ran full diagnostics and did a visual/physical inspection from above and below.
Apparently there is no problem. He said these are designed to drop off pretty quickly, even when you're accelerating. Still didn't get an answer as to why it's hanging out in the negative and at 0 while driving.
Will someone reply, maybe with a video of your boost gauge from a stop, through the gears on local roads, and at speed on a highway?
Thanks!
