xsport4e
So I’ve also been getting that annoying clunking noise coming from my front driver side suspension on civic sport for over a year now, what I thought was maybe the spring. However, I finally traced it down to simply a loose battery tie down. The loose battery was moving around rubbing against the frame on small bumps and turns causing that annoying clunking. I tightened it down and the noise is GONE.
Those of you getting any kind of clunking noise just make sure your battery tie down is TIGHT.
