Buzz_hatch
Does the Civic 10th Gen side marker on the front fender blink with the turn signal? If not, is there a way to get it to do that?
And then splicing them.would require cutting wires.
If you do this, can you post a how-to?Does the Civic 10th Gen side marker on the front fender blink with the turn signal? If not, is there a way to get it to do that?
2821Does anyone know the bulb type needed in the side turn signal? I want to change mine to a white bulb.
I don't plan to since the Touring has lights on the mirrors, but it's very basic.
Unplug the wire harness to the sidemarker.
Find the +12v wire from your headlight's turn signal, connect to the +lead of the sidemarker.
Ground the other side.
Before I DIY'ed it on my old car and had it wired to both my parking lights and turn signals so that they flash in inverse with turn signals. Just google it, it's easy.
so the (+) side marker to the (+) turn signal or (-) side marker to the (+) turn signal?This is an easy mod, run the ground on your side marker to the power supply side on the front headlight turn signal. I was researching the connector so I can built a plug and play mini harness for myself. I dont want cut into the harness like my last car.
Yea what’s up?so the (+) side marker to the (+) turn signal or (-) side marker to the (+) turn signal?
still can not figure out how to make the side marker alternating blinking signal and still keep the parking lightso the (+) side marker to the (+) turn signal or (-) side marker to the (+) turn signal?
