Replacing EXL tires - Can I go 225/50/R17?
PilotCivicEXL
CivicEXL
Norwalk
Civic EXL 2016
I have 2016 EXL with tires rating 215/50/R17. I was considering either the Bridgestone Turanza Quiettrack or Michellin Defenders or Bridgestone Ecopia
Here are my options with Costco deals ($150 off)
Bridgestone Ecopia 70,000 mile with eco - about $650
Michellin Defender LTX 70,000 mile that will last longer - About $800 ( only available after Nov 22nd)
Turanza Quiettrack 80,000 mile - about $680
I'm not able to find the Quiettrack in my size (backordered for too long) but able to find it slightly wider 225/50/R17. is it okay to use this wider tire?
Homer2556
Robby
SC
'17 Civic Touring sedan (mine), '12 Ody Touring Elite (the wife's)
The aspect ratio is the same, but because it’s a wider tire, the sidewall is taller, which will cause the speedo to read inaccurate. If your wheel width will accommodate, I think you would be better to find the Turanza in 235/45R17. This tire has nearly the same overall diameter as it’s 215/50R17 brother. The downside to this larger tire is the increased weight. It will make the car feel a little slower.
The 225/45R17 is a little smaller than the stock size, so the speedo will register inaccurate, but in the opposite way.
arsh88
Wisconsin
2018 Honda Civic Hatchback EX
Options to not mess with speedometer are 215/50/17 or 225/45/r17 unless you want to size up to 235/40/r18's. I kept 215/50s rathre than 225/45's but that's up to you.
PilotCivicEXL
CivicEXL
Norwalk
Civic EXL 2016
Thank you both for the suggestions. Thankfully, I got the right size tire at a different costco store
