Replacing 2016 Touring Stock Subwoofer
Whitest Russian
United States
Civic
I'm interested in replacing the stock Subwoofer in my Civic. All of the threads I've found have just added a second sub in the trunk.
Is it just too much effort replacing the stock sub with a new one?
SpartanSi
Michigan
Acura MDX and Honda CR-V
I was wondering the same thing. Seems like it would be easy to swap out the speaker and add an amp....
Doc_C
Omaha
2017 WOP Civic Si Sedan
The problem isn't that it is difficult. The problem is there are not very many Free Air woofers on the market. The other problem is you aren't going to get the sound or increase in bass you're looking. With the market pricing Free Air woofers at a premium, you'll get more bang for your buck just adding a sub w/ a traditional box.
Doc_C
Omaha
here's the problem with crutchfield... 1 of those subwoofers is actually designed for Free Air use. As a consumer you wouldn't know that unless you knew what you were looking for. Also, none of these are actual direct fit replacements as noted at the bottom of each.
Honda Civic 10th gen Replacing 2016 Touring Stock Subwoofer upload_2017-10-3_14-7-14
The issue with putting a sub that's designed to be a in box (ported or sealed) in a Free Air scenario is just that. It was never designed to function properly under those circumstances. Think of it like putting a Ferrari motor in a semi. Two pretty cool engineering feats in their own right, but together make one giant turd.
Whitest Russian
United States
Civic
Thanks for the info, it makes sense. I don't want to give up trunk space so I guess I'll stick to the stock subwoofer for now. Maybe I'll get an under the seat one if I feel like it.
