Removing 12v front socket
macrossranma
macross
Civic SI
Anyone have any diy how to remove the front 12v accessory socket? Mine is not working and there are no blown fuse
latole
Vaudreuil,Quebec ,Canada
How do you check fuse ? You need a meter, by eye sometimes you can't see .
Did you check the right fuse ? It is the inside car's fuse box.
Are you sure socket is not working ? It is not what you plug in is not working ?
Did you plug something you know it broke the socket ?
See the dealer if car is on warranty.
macrossranma
macross
Civic SI
Yeah i checkef the fusebinterior fuse box #29 even changed the fuse to new one tried different plugs not working
Swank
Calgary
2018 Civic Si Coupe Black
No DIY but first steps are to remove the little rubber mat which will reveal a small notch at the bottom of the panel where the 12 socket resides. I used a small pen sized flat blade screwdriver and gently pried to the side. Wrap it with cloth to minimize the risk of a slip and scratch. Once you get that cover off you'll have some wire length to play with and should be able to figure out how to unclip and take it apart.
3:12 in this video should help makes sense of my rambling -
