Ghostinnc
- Jul 8, 2016
- 18
- 763
- 677
- North Carolina
- 2016 black pearl Civic EX-T coupe
- Vehicle Showcase
Not sure what color you have but these are mine on black pearl. both front and back are the same sizeOrdered mine from ICBMotorsport (front and rear for coupe). Waiting to get them and I'll post some pics.... Any advice on how to install the new emblems ?
1)Rear-pull trunk lid liner down to expose inside of emblem cut 2 tabs off carefully then gently pry off emblem from the top lots of wiggling use plastic pry tool if you have one, I used a flathead screwdriver with rag on tip so not to scratch or dent sheet metal once off clean off any residue with some rubbing alcohol. The cleaner the surface the better the adhesion, peel off back of emblem and center accordingly push down hard and hold for about 2 minutes It should stick pretty good
2)Front-easy really just pry off from the front should pop right off but be careful wiggling works the best follow the same instructions from the rear emblem. Btw the oem front emblem broke in three pieces but that's because of my impatience, good luck post pics when your done
